Wheels That Fit Fiesta Brakes
14 replies to this topic
#1 adam_93rio
adam_93rio
  • 3,271 posts
Posted 05 March 2012 - 06:31 PM
So I've now got a fiesta brake conversion and was wondering what 10" wheels people have had fit over them. With pictures of clearance etc, could be used as a directory.
I'm hopefully going to be putting my 3.5" steels over them, can anybody tell me what the smallest spacer is need is
#2 charie t
charie t
  • 3,153 posts
Posted 05 March 2012 - 10:22 PM
I didn't actually get steels to fit, 3.5, 4.5 or reverse rims, even with 1" spacers. I did have gb 004, minator and 100+ fitting without spacers. Dunlop D1 needed a small 1/4" spacer with some caliper smoothing. Any wheel bearing issues would have seen the wheel wrecked though
#3 adam_93rio
adam_93rio
  • 3,271 posts
Posted 05 March 2012 - 11:22 PM
I was thinking about getting an old calliper and grinding it down, it doesn't seem too far off sitting right and the part of the calliper isn't hollow. Might just try it then do a strength test
#4 bmcecosse
bmcecosse
  • 9,699 posts
Posted 06 March 2012 - 12:01 AM
Exacton alloys fit with plenty of clearance
#5 adam_93rio
adam_93rio
  • 3,271 posts
Posted 06 March 2012 - 09:45 PM
I stood my hub assembly up today and put a wheel in place and it does touch the rim, looks like it'll be too much to remove from te calliper. But doesn't look like it will need much of a spacer
#6 miniman24
miniman24
  • 1,696 posts
Posted 08 March 2012 - 02:39 PM
Do you reckon 10 x 6 wellers would fit? Got fiesta brakes and thinking of getting a set :)
#7 kevinr6
kevinr6
  • 61 posts
Posted 08 March 2012 - 04:55 PM
6x10 ultralights fit
#8 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 08 March 2012 - 05:27 PM
6x10 starmags fit
10" revos. think i had a 5" and a 6" rim on my shell when it was rolling
#9 miniman24
miniman24
  • 1,696 posts
Posted 08 March 2012 - 05:45 PM
Found a pretty decent list here, on page 23 about half way down:
http://www.theminifo...fiesta__st__330
Apparently the wellers will fit :)
Edited by miniman24, 08 March 2012 - 05:46 PM.
#10 adam_93rio
adam_93rio
  • 3,271 posts
Posted 18 March 2012 - 03:03 PM
I'm not sure how you couldn't get 3.5" and 4.5" wheels to fit with an inch spacer. By my test, 10mm is plenty. See pictures below
Looks tight but still clears
By a few mm
However I think I need longer studs
Also I've been reading that thread and there is someone on there who tested how thick the cast was on the callipers. He says with enough ground off to clear the wheels, there is stil about 1/2" of cast there
Edited by adam_93rio, 18 March 2012 - 03:03 PM.
#11 tommy13
tommy13
  • 878 posts
Posted 18 March 2012 - 05:01 PM
I got the standard Mk1 rims (3.5"?) to fit over Mk2 Fiesta calipers with some grinding of the caliper and a 5mm spacer. Nice thing about a 5 or 6 mm spacer is you don't need to use longer studs.
#12 bmcecosse
bmcecosse
  • 9,699 posts
Posted 18 March 2012 - 06:35 PM
As above -are you using MK I or MK II calipers? Mk III etc are no use......
#13 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 18 March 2012 - 06:39 PM
those are MK2 in the pictures.
#14 bmcecosse
bmcecosse
  • 9,699 posts
Posted 18 March 2012 - 06:41 PM
Maybe they are larger than the MK I calipers - which is what I used.
#15 adam_93rio
adam_93rio
  • 3,271 posts
Posted 18 March 2012 - 06:50 PM
Bmc- did you try steelies on your mk1 callipers?
And thanks Jordie, they are mk2 callipers as bought from Jordie.
I'm very tempted with grinding some off the callipers
