Waxoyl In An Aerosol Spray Can Any Good?
26 replies to this topic
#1 duffman
duffman
  • 540 posts
  • Local Club: Doncaster Mini Owners Club
Posted 05 March 2012 - 09:59 AM
been to get a new applicator and some wayoxl this morning and noticed they do it in a spay aerosol can, its expensive at £9 a tin but is it any good? i've bought some to test as its quite a large can so should be enough for a couple of applications.
anyone used it before?
i'll let you know how i get on later.
#2 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,033 posts
  • Name: Neil
Posted 05 March 2012 - 10:06 AM
Yes i have used it a lot and they work fine. Yes expensive but then again how much do you need to use??
#3 mini-luke
mini-luke
    Postman Pat
  • 2,362 posts
Posted 05 March 2012 - 10:07 AM
My main issue with is was the lack of any extension probe for getting in the box sections.
#4 minimat
minimat
  • 690 posts
  • Local Club: anglian mini club
Posted 05 March 2012 - 10:42 AM
I always keep comma wax seal in a aerosol for small bits but bigger tins for a whole car as it's much cheaper and i have a compressor to fire it in with,much easier.
#5 duffman
duffman
  • 540 posts
Posted 05 March 2012 - 11:53 AM
well i agree, it could do with a probe or something to spray it into the nooks and cranies, box sections etc.
was quite messy if i'm honest due to the nozzle being quite small and suffering from build up which dripped everywhere lol.
there was enough, JUST to do the whole unserside but if i'm honest i wouldn't use it again for a full coating, however it is brilliant for quick application to small areas like the external battery box, sub-frames etc.
overall, in my opinion, not a bad idea to keep a tin handy to coat any work you've just done but for a full underside coating, get the applicator and the big refil tin.
#6 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 05 March 2012 - 05:32 PM
the cans are ok of a small area like a door or something but you would need lots to do a whole mini
#7 matt615
matt615
  • 923 posts
Posted 05 March 2012 - 05:37 PM
I use Dinitrol in spray cans. I've been told it is much better than waxoyl for rust proofing. You can get dinitrol cavity wax in cans with a long attachment for getting into box sections.
http://www.ebay.co.u...=item4ab227bbc5
Edited by matt615, 05 March 2012 - 05:42 PM.
#8 sport2000
sport2000
  • 279 posts
Posted 05 March 2012 - 06:55 PM
Dinitrol is more heavy duty, I have used cavity wax version and also Dinitrol 4941..
#9 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 05 March 2012 - 07:42 PM
Another Dinitrol product is AV30. Its very thin but gets in everywhere however if you are using any Dinitrol product especially in spray form YOU MUST use a mask. If inhaled it will waterproof the linings of your lungs causing you to drown in your own fluids.
This is not a scare tactic folks just a fact so please take heed.
#10 sport2000
sport2000
  • 279 posts
Posted 05 March 2012 - 09:38 PM
Drown in your own fluids... Really?... never had a problem...
Can't remember if I used a mask to be honest!
I must of or I be in the ground by now!
#11 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 05 March 2012 - 09:46 PM
Having worked with this stuff for a long time and seen the risk assessments and COSHH reports about it over exposure will cause lung damage. We heed the warnings as we tend to use a lot of it on civil aircraft.
Its like any water displacing fluid spray etc you inhale it and it will cause you to cough. Its like anything good that works tends to have bad side effects for example Trich and MEK a brilliant cleaner but really nasty. Our industry is becoming really health and safety conscious and some of the products we have and are still using are really bad for your health.
Having just looked at the safety data sheet for the product you use it says in brief exposure to use a respiratory protective filter and in intensive or longer exposure to use self contained respiratory protective device.
Some of their products are safer than others but wearing a mask is an easy thing to do. Better to be safe than sorry.
#12 conlad
conlad
    Previously known as ct16mini.
  • 2,054 posts
  • Local Club: Hilltop Minis
Posted 05 March 2012 - 09:49 PM
Which is better in terms of price and the rust proofing capabilities? Waxoyl or that Dinitrol?
#13 sport2000
sport2000
  • 279 posts
Posted 05 March 2012 - 10:19 PM
I think I used a mask although not an expensive one..mainly dust protection with a valve built in...
Dinitrol is better than waxoyl by far, just my opinion..
#14 conlad
conlad
  • 2,054 posts
Posted 05 March 2012 - 10:24 PM
Why exactly? :proud: It protects better?
#15 sport2000
sport2000
  • 279 posts
Posted 05 March 2012 - 10:36 PM
Protects better, problem with waxoyl is it wears off easy plus not very heat resistant.
Dinitrol is used by most vehicle manufacturers, hence not many rusty cars,
I've just found Dinitrol harder wearing.. I'm pretty sure ministry of defence tested it and coated metal with dinitrol and left in salt water for quite a while with outstanding results..
I'm sure google would come up with some research results..
