Hi,
i'm converting my drum brake all round mini to having metro 4 pot calipers on the front and would like to know which master cylinder i should use :)
thanks
Master Cylinder-Drum To Metro 4 Pot's
monster_mini
, Mar 03 2012 03:09 AM
3 replies to this topic
Posted 03 March 2012 - 03:09 AM
Posted 03 March 2012 - 11:35 AM
Try the Somerford Mini web site to find out exactly which parts you require. They also have the bits to connect up both ports on the Metro calipers.
Posted 03 March 2012 - 11:50 AM
Any should do, Metty calipers have pretty much the same piston area as the Mini's. If you're buying one anyway the "yellow band" GMC227 would the be best without a servo, or you could use the Metty unservoed one with matching rear wheel cylinders & get the same effect.
Posted 04 March 2012 - 09:00 AM
okay, cheers guys, ouchh its abit expensive mind!
