I.c.e. Upgrade For Bottom
145 replies to this topic
#1 blueturbomini
blueturbomini
  • 290 posts
  • Local Club: LSMOC
Posted 01 March 2012 - 08:50 PM
After some limited sucess in a few sound off competitions, i have got the bug and now want to upgrade and do better.
The front of the car will stay the same speaker wise
The sub and 6x9 are going
In there place i am installing this lot
I am hoping to fit the subs in the rear side bins, in a couple of 20 litre boxes
When screwed up i should end up with a pair looking a bit like this
All because i want to work around my roll cage and keep the rear seat
I still need a few bits for the sub boxes and i will update when i get some more done.
#2 RossKnight
RossKnight
    One heck of a member
  • 2,539 posts
  • Local Club: JKSA MOC
Posted 01 March 2012 - 09:11 PM
looking good, can't advise on anything, but want to see it progress :D
#3 freshairmini
freshairmini
  • 1,718 posts
Posted 01 March 2012 - 10:26 PM
I love the tweeters in the door. Great idea, is it just a panel welded or bolted to the door?
(null)
#4 freshairmini
freshairmini
  • 1,718 posts
Also what speakers/HU/amps/subs are you using?
(null)
#5 blueturbomini
blueturbomini
  • 290 posts
  • Local Club: LSMOC
Posted 02 March 2012 - 08:05 PM
Thanks for that, got to get moving on it as the shows are starting soon
#6 blueturbomini
blueturbomini
  • 290 posts
  • Local Club: LSMOC
Posted 02 March 2012 - 08:09 PM
(null)
(null)
thanks, the tweets are held in place with a 2 part silicone type glue, been there for about 2 years so sticks pretty well
I will post up the tech stuff about what was in/now going in the car over the weekend as it is all in the garage
#7 blueturbomini
blueturbomini
  • 290 posts
  • Local Club: LSMOC
Posted 03 March 2012 - 01:56 PM
The kit that was in the car to start with was
JVC PDR61 headunit
Infinity kappa 3 way components up front
Pair of Audiobahn AS690 6X9 under rear seat
Audiobahn AW1051T 10" sub mounted on rear parcel shelf with the flame basket showing
Powered through a JL Audio 600/4 amp
The parts of the system that are coming out are
the head unit
6x9 and the sub
going to sell on e-bay probably
They are being replaced with
Pioneer DEH-P88RS headunit
A pair of DLS RW10 subs in 18/20 litre enclosures( in rear bins)
And a second JL Audio 600/4 amp just to run the subs.
I think the hardest part will be building my sub boxes as i am trying to work around a roll cage, at least it will give me something to think about. Let me know what you think and i will update hopefully tomorrow after some more work on the sub boxes.
#8 Brams96
Brams96
  • 2,308 posts
Posted 04 March 2012 - 02:57 PM
Nice gear you've chosen. From experience you will find building the boxes a PITA.
Check my build in the ICE build section for some pics on how I did my box. I used 12mm mdf strips about 30mm wide & built up the curve at the back. You will also have to have the front of the box where the sub mounts sticking out a bit & take into account the volume of the sub sticking into the box to get 20L from it, at a guess I think mine worked out between 16-18L which is a little bit small for my sub & my mounting depth is only 110mm (yours is 150mm). DLS recommend using 18mm MDF but that would make the internal volume too small for fitting in a bin.
Are you going to use fiberglass at all on your box?
edit: 1 more thing, use a speaker grill or some sort of cover/protection for your sub. If your doing sound competitions you'll get more points for it. Contact Ruckus too about the judging rules & criteria as he's one of the judges that do SMD & L2B & is always happy to help out.
Edited by Brams96, 04 March 2012 - 03:01 PM.
#9 blueturbomini
blueturbomini
  • 290 posts
  • Local Club: LSMOC
Posted 04 March 2012 - 04:16 PM
To be honest i fully expect you are right about the pods, then again the car isn't called BOTTOM for nothing but thats another story. I have looked are your bin builds obout 20 times, the roll cage does restrict the width a little but i can come in over the rear seat, as my car has front bucket seats and 3 point harnesses, so no rear passengers to worry about. I will be fibre glassing the open area of the box but as it is in the garage with no heating, i am waiting for the first one to set up. Should be fun though as i have never used fibre glass before.
#10 freshairmini
freshairmini
  • 1,718 posts
Posted 04 March 2012 - 09:54 PM
Surely it's going to be a lot easier to create a fibreglass box by just building up a mould in the bins? Mdf would be a pita because it would take ages to get the shape right.
(null)
#11 Ruckus
Ruckus
    Ice Ice Baby!!!
  • 2,071 posts
  • Local Club: SMOC
Posted 04 March 2012 - 11:58 PM
(null)
I have a feeling BlueTurbo wants to avoid loads of GRP work due to a lack of experience with it, which is fair enough.
Also he's is keeping me out of the spot light, but this IS a Ruckus guided reload ;)
The kit (especially the HU) is all top class. I can't wait to get my hand on it for setup :D should add up to something really special.
Edited by Ruckus, 05 March 2012 - 12:01 AM.
#12 Brams96
Brams96
  • 2,308 posts
Posted 05 March 2012 - 02:50 PM
Nice one Joe, I look forward to seeing some pics & hearing it at some shows.
#13 blueturbomini
blueturbomini
  • 290 posts
  • Local Club: LSMOC
Posted 05 March 2012 - 06:34 PM
(null)
Joe is spot on about the glassing, mainly as i have only tried it once before and ended up with more on my gloves than what i was working on, also my garage has no heating in. Due to this the cloth and 2 part resin/hardener that i am using on my sub boxes, which at around 20 degrees goes off in around 2 hours, was still curing tonight a 6.00 when i got home from work.
#14 blueturbomini
blueturbomini
  • 290 posts
  • Local Club: LSMOC
Posted 05 March 2012 - 06:35 PM
With a bit of luck it should get it's first big test at L2B
#15 Ruckus
Ruckus
    Ice Ice Baby!!!
  • 2,071 posts
  • Local Club: SMOC
Posted 06 March 2012 - 09:50 AM
if we do it this year... we are not happy with them. :(
