Rover 3.5 V8
103 replies to this topic
#61 v8mini
v8mini
  • 726 posts
  • Local Club: Minis on the run
Posted 29 December 2006 - 12:13 AM
think the tank is about 7.5 - 8 gallon, its an optional bigger tank than what they normaly supply with the kits.
measures just under 450 x 450 x 190 on the outside.
yes they do A series frame that is basicly the same as this, is shown on the Video they sent me
Edited by v8mini, 29 December 2006 - 12:13 AM.
#62 ed4ran
ed4ran
    Cadwell Event organiser
  • 2,849 posts
Posted 29 December 2006 - 12:34 AM
Got it fitted yet? :)
#63 v8mini
v8mini
  • 726 posts
Posted 29 December 2006 - 12:54 AM
not yet, just got back from visiting the folks in Essex, and not sure if the misses will let me get it in before new year :) , as we've got a few job's to get done on the house. but then again she will want it out of the front room, before she starts child minding again in the new year, so might just have a chance.
Edited by v8mini, 29 December 2006 - 12:55 AM.
#64 mini93
mini93
    He's just too casual!
  • 8,615 posts
Posted 31 December 2006 - 01:44 AM
bhaa....who needs permission just go there in the evening instead of watching tv get the good ol hammer out and when she asks what ur doing say she wont let you have any time off from jobs in the day to play about
#65 Retro_10s
Retro_10s
    Moderator
  • 10,138 posts
Posted 31 December 2006 - 01:57 PM
so errr, when do you want to build me one mate?... i'll buy you a pint!
#66 Dragonstone
Dragonstone
    Starting My Mini Up
  • 3 posts
Posted 16 February 2007 - 09:50 PM
Hi I was looking on yourtube and found your vid on there I wonted to ask you loads but reading the thread almost all has been answered for me so hoping to bump into you at Combe and have a good look at you fab car.
David
admin at cento-rebels.com
Edited by Dragonstone, 16 February 2007 - 09:51 PM.
#67 ed4ran
ed4ran
  • 2,849 posts
Posted 15 March 2007 - 12:12 AM
Have you fitted the new front frame yet? Has it improved 60+mph handling?
#68 v8mini
v8mini
  • 726 posts
Posted 11 April 2007 - 10:21 PM
started fitting the Z cars front subframe, not finished it yet. i think my front end might be abit on the p155, as alignment is out a bit.
would have probably got more done, but went flying sunday and monday
Attached File  PHTO0052.JPG   142.2K   60 downloads
Attached File  PHTO0053.JPG   147.09K   45 downloads
Attached File  PHTO0057.JPG   133.64K   50 downloads
Edited by v8mini, 11 April 2007 - 10:36 PM.
#69 ed4ran
ed4ran
  • 2,849 posts
Posted 11 April 2007 - 10:31 PM
Oow, will defiantly have to say if it solves the problem, are you going to get the suspension setup or should it be ok/already setup with that subframe? Guessing the front and rear toe will need setting at least?
Had mine up to about 80 and it was quite light steering (same as about 60), but no vibrations after changing the rear bolts from 12mm to 1/2".
Any further plans once the subframe is on? or anything left to finish or adjust?
Ed
Edited by ed4ran, 11 April 2007 - 10:32 PM.
#70 Turbo Tom
Turbo Tom
    Starting My Mini Up
  • 1 posts
  • Local Club: Malta Mini Forum
Posted 26 April 2007 - 11:02 AM
incredible mate
i was thinking of something along the same lines but with twin turbos :lol: >_<
having to think it over carefully now that i ve read about all ur handling probs with a standard engine!!!
#71 v8mini
v8mini
  • 726 posts
Posted 30 May 2007 - 08:59 PM
The subframe does make the car feel better on the road, and it’s not been setup yet. :proud:
After a couple of days use fuel pump packed up due to a bit of ally swarf from the new fuel tank getting in it. i knew i should have swilled it out first.
Few days later the ECU packed up, due to coolant getting in it when i was getting air out of the system, ECU was right next to the header tank.
So now’s the time to get a Megasquirt ECU, and i can ditch a lot of the old rover kit that’s known to be temperamental in there old age. Also the advance of the dizzy isn’t that good, so i can lock that off and control that with the Megasquirt as well.
just waiting for it to turn up..
#72 ed4ran
ed4ran
  • 2,849 posts
Posted 30 May 2007 - 09:01 PM
Cool, what version of MS are you going for, and what features you planning?
are you going to run 2 WBO sensors or just one? or even a NB? :proud:
#73 v8mini
v8mini
  • 726 posts
Posted 30 May 2007 - 09:22 PM
I'm getting MSnS v3. just going to go for NB sensor for now, this really was not a planned expense at this point, as i'm planning on spending £200 on another R/C airplane next month.
www.extraefi.co.uk
just going for a dizzy based setup, not bothered about coil packs ect. i just want to get the cars running reliably and smoothly.
must admit i'm getting bored with it now, just dont have time or motivation for it. you think its going somewhere and somthing else goes wrong. but i know id never get the time or money back on it. quite fancy a basic clubby estate now
#74 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 30 May 2007 - 09:32 PM
thought things had gone quiet on this
#75 ed4ran
ed4ran
  • 2,849 posts
Posted 30 May 2007 - 09:34 PM
:proud: I kinda know what you mean, after everything i sometimes wish i had stuck with an A series (especially after i found out what some/most of the problems i had with it where!!!) and a standard car as parts are easier to get and replace.
