Electrical Wire Questions
Posted 28 February 2012 - 04:34 PM
second questions is im going to be rewiring my whole headlamp and spot lamp aassembly with all new wires with relays and new switch, is 12 gauge good enough or should i get 10, 10 just seems so large
Posted 28 February 2012 - 05:22 PM
For the headlight relays, 16 to 18 AWG was good enough for the factory. 14 to 12 AWG is an improvement, 10 AWG is overkill and probably will not fit in your relay bases or fuse holders. The Ampacity of 14 AWG is nearly 1.5 times that of 16 AWG so it will offer a lot more current capacity while remaining fairly flexible and easy to work with.
Posted 28 February 2012 - 09:22 PM
i think i will go with 12 gauge then, seems like a good spot
thanks!!
by the way, how do you guys rate your wire size?
Posted 28 February 2012 - 09:43 PM
Posted 28 February 2012 - 10:15 PM
As Dan said, the appearance and size of the conductor (not the jacket) is highly influenced by the strand size and lay of the stranding. As a general reference, 2 AWG will have copper with a diameter close to 5/16" (about 8mm). For comparison, the copper in 8 AWG is close to 5/32" (4mm) in diameter. Again, this is highly influenced by the stranding. Regardless, #8 is smaller than #2 so something is not correct. Perhaps you are looking at the jacket diameter and not the copper diameter.
You asked how "you guys rate your wire size". Do you mean how/where did the AWG standards come from or something else?
Posted 28 February 2012 - 10:19 PM
- and i ment how are wire size rated in the UK
Posted 28 February 2012 - 10:48 PM
By the cross sectional conductor area.
Expressed in square mm.
AWG = American Wire Gauge. When all things were imperial we used to have a wire gauge of our own over here, it wasn't quite the same as in the US though. We had SWG, Standard Wire Gauge.
Posted 29 February 2012 - 12:12 AM
Every European application I have worked on in my job has specified wire size by its area in mm2 as Dan said. That is why I was surprised to see you were referencing wire by its gauge, and that is also why I gave you the 35mm2 figure (for 2 AWG) in my first post.
Posted 29 February 2012 - 01:03 PM
Posted 29 February 2012 - 01:12 PM
Something close to 1/4" will work, particularly if it is listed as #2 AWG or 35mm2. As mentioned above, don't confuse this with the jacket diameter and if replacing the main cable to the front of the car, remember the cable still has to fit the track on the car's underbody.
Posted 29 February 2012 - 01:21 PM
So you could have a 1/4" cable (diameter) but with very thick wire stands. But compared to the same 1/4" cable with a greater quantity/fine strands you would have more surface area, so a more current could flow. hence why you need to buy wire that is graded by the proper standards, either american AWG or the british mm2
Am I right in saying that?
Edited by freshairmini, 29 February 2012 - 01:21 PM.
Posted 29 February 2012 - 07:54 PM
Posted 29 February 2012 - 09:05 PM
mine prolly has about 20-30 strands in the 1/4 area
Posted 29 February 2012 - 09:34 PM
Not for this application. Smaller strands give greater flexibility but are more prone to corrosion.so smaller the strands the better?
