Anyone Think A Weber 40 Dcoe Is Good For My Engine Spec
59 replies to this topic
#31 Ivor Badger
Ivor Badger
  • 846 posts
Posted 27 February 2012 - 11:41 PM
Swan neck is terrible - and a 40 DCOE is too small for a 1275 anyway - you need a 45 DCOE - and deep pockets to pay for the heavy fuel consumption! HIF 44 is THE way to go.
are you suggesting 15mpg is heavy fuel consumption?
#32 Cooperman
  • 23,278 posts
Posted 27 February 2012 - 11:47 PM
Twin SU's, Webers, etc, used to be fitted to improve performance on the best available manifold and combined with really good cam, big-valve head and so on. Now it seems that some people fit them for looks and noise. Each to their own, but what a waste of potentially good carburation by fitting poorly designed manifolds (swan neck) just to get a different noise.
#33 bmcecosse
bmcecosse
  • 9,699 posts
Posted 27 February 2012 - 11:53 PM
Sort of gurgling/choking noise with a swan neck - I imagine....... 15 mpg??? Crivens - didn't think it would be THAT bad Ivor???
#34 Ivor Badger
Ivor Badger
  • 846 posts
Posted 28 February 2012 - 02:37 AM
15 in the rally car, road sections help. 10- on the track
#35 minilee94
minilee94
  • 3,523 posts
Posted 28 February 2012 - 06:11 AM
Surly it depends on how you drive if you have got a lead foot then that when you would get poor fuel consumption and I was only going to use a swan neck so I don't need to cut the bulkhead but its fine with me cutting the bulk section out to fit a box
#36 minilee94
minilee94
  • 3,523 posts
Posted 28 February 2012 - 06:19 AM
And why would it be better to get a 45 weber
#37 freshairmini
freshairmini
  • 1,718 posts
Posted 28 February 2012 - 10:30 AM
beause they dont allow enough air through, its a larger choke carb, which is better suited to your engine size.
#38 mk3 Cooper S
mk3 Cooper S
  • 5,569 posts
Posted 28 February 2012 - 12:13 PM
Spot on
Our 8.4 v10 Viper averages 11- 15 MPG and that has 600bhp.
So 15 mpg from a 100 bhp mini is bad in my book.
#39 freshairmini
freshairmini
  • 1,718 posts
Posted 28 February 2012 - 12:47 PM
its seems that the costs/performance outweigh the benefit compared to an SU. If the only reason for fitting one is for the noise, get an HIF44 with an ITG foam filter. You get alot of induction noise, plus its easier, cheaper, and more beneficial in terms of performance for your spec to have.
#40 minilee94
minilee94
  • 3,523 posts
Posted 28 February 2012 - 06:21 PM
Okay well we will leave this thread as it is I can't seem to get a simple awnser so many people saying get it so many people saying don't
#41 RossKnight
RossKnight
    One heck of a member
  • 2,539 posts
  • Local Club: JKSA MOC
Posted 28 February 2012 - 06:31 PM
You made a thread asking for people opinions...
And thats what you got... opinions?
There's no right or wrong, I could stick a weber on an 850cc and say it sounds awesome, but an SU would be much better. A lot of very knowledgeable people commented saying that a HIF44 would be a lot better for your spec, but you still seemed set on using a weber, so if you want to, do it...
But bare in mind the advice that's been given in this thread
#42 minilee94
minilee94
  • 3,523 posts
Posted 28 February 2012 - 06:40 PM
I know I asked for opinions but its annoying all the way through the thread different people saying different things iv spoken to a performance specialist who said it would be okay will just need a bit of tinkering and that's somone who tunes minis everyday as a job then you get some people saying nope it won't work and that's just them that's fitted maybe like 2 webers in there life
#43 RossKnight
RossKnight
  • 2,539 posts
Posted 28 February 2012 - 07:21 PM
Literally every single post on this thread from people has been extremely good advice, no-ones been saying different things either, majority of the people recommended a HIF 44, because a Weber has poor fuel economy and doesn't work too well unless you have a very high lift/duration cam. Also someone pointed out that a 40 dcoe would not flow enough and you'd need a 45 dcoe.
Don't make out like this thread has been 'annoying' because there's been some top advice here... but listen to you 'performance specialist' if you wish.
#44 mini93
mini93
    He's just too casual!
  • 8,615 posts
Posted 28 February 2012 - 07:34 PM
webber 40's fine, otherwise my engine builder would ahve told me to sack mine off ages ago and it still has 100 at the wheels
#45 MJWarren
MJWarren
  • 705 posts
  • Local Club: DCMOC
Posted 28 February 2012 - 07:41 PM
I agree, weber 40 would be fine, can give good results if set up properly.
Lots of people use them.
Edited by MJWarren, 28 February 2012 - 07:43 PM.
