1st let me explain more clearly what I mean about the engine plate.
The engine plate does not distort. The cam plate does. The engine plate recesses due to the eroding effect of oil flowing between the front face of the engine plate, and the thrust face (camshaft side) of the cam plate.
If the cam plate is bolted too tightly, it compresses at the bolt holes. The white metal surface spreads out a little. If the cam plate is then re-used again, as I have done, when the already compressed cam plate is bolted down, it has the effect of raising the stretches of cam plate between the bolt hole locations. Arching the cam plate. Thus a gap is created between the front face of the engine plate, and thrust face of the cam plate, and oil flows through these gaps. The hot oil under pressure over many engine miles, has the effect of eroding the front face of the engine plate. But the rear face of the engine plate stays flat.
However.
I've now noticed, that the threads in the face of the block, that secure cam plate, have been pulled slightly proud of the block face. This I think might have resulted in the engine plate not sitting completely flat against the block, and I have had oil leaking through the gasket at the rear of the engine plate at this point. In my case to the inside, and not the outside as I think you are describing.
Regarding the oil feed to the camshaft. On the Spridget block and I would imagine the Mini block is the same in this respect, there is an oil feed from the front crank main, directly to the front camshaft bearing. The bearing itself, has a slotted hole that extends towards the front. This slotted hole lines up with the crank main oil feed. Oil enters the camshaft bearing at the rear of the slotted hole, and each sweep of the camshaft the front groove in the camshaft, must "collect" a slug of oil from the front of the oil slot in the bearing, which it carries round to the cam plate hole. At least that's how it looks.
Edited by slpj24, 29 February 2012 - 12:20 AM.
