Oil Coming Out Of Breather
Posted 26 February 2012 - 07:50 PM
The engine is an unknown item, what we do know is that it has been rebuilt to a high spec, been told by the guy who bought the car the engine came out of it's a 1400 trackday engine only other thing we know about the engine is it has a metro turbo box and cross pin diff, and the guy spent £700 having work done on the head. and i've found out it has a very light flywheel
The engine runs fine and sounds sweet but when the oil pressure reaches 70/80 then oil starts to seep out of the filter on top of the breather
The timing cover has a 90 degree bend coming out of the case but no cannister with the wire mesh in it
Now if you take off the oil cap then it stops the oil from coming out
Any ideas
Colin
Posted 26 February 2012 - 09:26 PM
after a few laps the catch tank would be half full
it was to do with the rings apparantly
Posted 26 February 2012 - 10:08 PM
AC
Posted 27 February 2012 - 12:53 PM
I would suggest a Manometer test on this engine. More than 2in of H2O at 6krpm with the oil cap removed means engine rebuild time. If its lower than that check for blockages (unusual).
AC
Thanks for the reply, but to be honest i've no idea what a manometer test is, could you explain in layman terms
COLIN
Posted 27 February 2012 - 04:07 PM
AC
Posted 27 February 2012 - 08:22 PM
No1 cylinder 13bar, No2 cylinder 13bar, No3 cylinder 13bar, No4 cylinder 13bar
any other idea's before i ring Andy tommorrow?
Posted 28 February 2012 - 07:48 AM
Posted 28 February 2012 - 11:40 AM
Also did you perform the test with the throttle wide open? if not please repeat the test with it open and of course dry and wet.
From what you say, I would have to say it sounds so suspiciously like the rings have gone, is it blowing any blue smoke out of the exhaust.
Posted 28 February 2012 - 02:47 PM
Yer when you did the compression test did you first do it dry and then do another test with a bit of oil down the bores? if so could you give both results.
No blue smoke out of the exhaust, last night when testing the engine i noticed that very little oil was getting to the rocker shaft, could this be a blockage
Posted 28 February 2012 - 04:45 PM
What about the rest of what I said?
Posted 28 February 2012 - 07:07 PM
Hi Andy its colin we yesterday about my engine blowing out oil, you suggested a compression test
Oh yeah, what did you find?
13bar across all pistons
whats that in PSI?
oh sorry about 200psi
ok engine all ok, how many breathers do you have on the engine?
just the one, well it's just an elbow
do you have a breather at the clutch end above the drop gears?
no! why?
sounds like you have a 998 drop gear case you need a breather on your engine! so first sort that out and phone me if still playing up
What a top man, didn't know me from adam but what a fantastic attitude, if this engine needs work doing to it it will be carried out by Andy at MLMotorsport
Posted 29 February 2012 - 11:31 AM
Yer that should help a fair amount, I would also ditch those terrible filters and plumb them back into the carburettor.
