Gauges Bouncing
8 replies to this topic
#1 Neildanks
Neildanks
    Captain Slow!!!
  • 889 posts
Posted 22 February 2012 - 08:54 PM
When the mini is running the temperture gauge bounces and the petrol gauge, but the petrol gauge doesnt register any petrol
is it the voltage regulator not working causing this, how can i check if it is working.
The temperture gauge seems to work but not the petrol gauge i have petrol in and power at the sender unit
#2 jsiggee
jsiggee
  • 383 posts
Posted 22 February 2012 - 08:59 PM
bad earth somewhere?
#3 Neildanks
Neildanks
    Captain Slow!!!
  • 889 posts
Posted 22 February 2012 - 09:09 PM
where would the earth be the tempeture switch all checks out and i suppose i can do a check on the petrol tank one
#4 Greenmini998
Greenmini998
  • 21 posts
  • Local Club: Guernsey mini owners club
Posted 22 February 2012 - 09:32 PM
hi the mostly cause a bad earth somwhere. But what gauges does your mini have ie separate 52mm smith gauges, or standard mini gauge behind stearing wheel. Voltage stabilizer can be likely culprit.
Hope I can help little more..
#5 jsiggee
jsiggee
  • 383 posts
Posted 22 February 2012 - 09:33 PM
not sure about the temperature gauge but whenever my petrol gauge plays up it turns out that one of the connectors has come loose! :D
#6 Neildanks
Neildanks
    Captain Slow!!!
  • 889 posts
Posted 22 February 2012 - 09:34 PM
sorry the gauges are two dial 1985 ritz
#7 Greenmini998
Greenmini998
  • 21 posts
Posted 22 February 2012 - 10:24 PM
if temp gauge and fuel gauge stop working you'll have to test the voltage stabilizer. Please check you conection underneath front panel near wiper motor.Old wiring can be right nightmare with corroaded connection blackened cabling. :ohno: Your Ritz is getting on a bit now and the wiring if orignal will be getting tired.. -_-
Greenmini998
#8 Greenmini998
Greenmini998
  • 21 posts
Posted 22 February 2012 - 10:28 PM
sorry that where you'll find wire to fuel sender.. also try disconecting the temp wire on the temp sender and earthing spade terminal directly to engine if working correctly temp gauge should go to max...
#9 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,138 posts
  • Name: Sean
This may help?
http://www.theminifo...tage-regulator/
