Engine Rotation Direction
#16
Posted 20 February 2012 - 09:46 PM
#17
Posted 20 February 2012 - 09:51 PM
I posted a bad description, no to finger tight, just checked it again torqued up, 11 tho.
If a new retaining plate does the trick, how does it work?? Could the new gasket be the problem, I would expect that it would only add 1 tho though !!
However I have just measured the uncompressed garket thickness and it is 34 tho !!! Seems a little thick, would a thinner gasket solve the problem ???
Edited by grahama, 20 February 2012 - 09:56 PM.
#18
Posted 20 February 2012 - 09:56 PM
Its a job for a lathe.Material is removed from the part of the sprocket which contacts the end of the cam when the nut is tightened. as I recall the sprocket is reduced in that area and that part of it is like a thin ringThat's how it came !! The one I took off didn't have it but hey ho should be fine if going in the right direction.
I don't understand what to get machined ?? If I take material off the sproke twont it will make the gap larger ???
How do I do this??
#19
#20
Posted 20 February 2012 - 09:58 PM
Start with a new plate. It is safer than messing with the thickness of the gear.
(5 new posts while I tried to complete this one lously reply. I shouldn't try to post while at work!)
EDIT: Gasket thickness does not influence cam endfloat. As mentioned earlier, by Pigeonto, the gear has a thin boss on it that extends through the triangle plate and touches the front of the cam. It's just the triangle plate and boss on the gear that control endfloat.
Edited by dklawson, 20 February 2012 - 10:00 PM.
#21
Posted 20 February 2012 - 10:28 PM
If shims were added between the cam and sprocket the end float would increase.Save your shimming for the very last job after you have corrected the cam end float,that is use shims to get the bottom sprocket perfectly in line with the cam one.No, torqued up to 65 lb/ft, the locating plate looked a 'little' worn but I don't see how a thicker / new one would help!! Shims over the end of the cam would take up the slack, but can't find any !!
Graham
#22
Posted 20 February 2012 - 10:39 PM
As a last resort I turned the triangle plate round, doesn't fit but got a bolt in to see how the sproket sat, and the end float. It has improved dramatically so I think a new plate is in order.
For the life of me I can't see how a thicker plate would work, maybe just too tired to think now, not usually this thick mechanical wise lol, but I will work it out, a diagram would be good if someone can help me out.
Graham
Sorry think I have got it, a thicher plate will allow the nut to push the cam further back into the block, taking up slack, a thinner plate will leave slack as the 'extra' bit on the sproket can't push the cam back properly when the nut is done up. Probably very badly explained but I get it now, Phew !!!
Edited by grahama, 20 February 2012 - 10:46 PM.
#23
Posted 20 February 2012 - 10:50 PM
#24
Posted 20 February 2012 - 11:01 PM
#25
Posted 21 February 2012 - 08:16 AM
Hmmm, will be an interesting day for you today when it all suddenly makes sense!! you will also notice that,no, the cam wont get pushed further into the block by a thicker plate.The cam will always be pulled up to the block side of the triangle plate,even if the plate was a mile thick,the inside(block) face of it will always be hard against the backplate and the cam end bearing diameter will be there too.That is where the cam is designed to be to put the dizzy drive spiral gear in perfect line with the dizzy drive shaft and the cam lobes in the middle of the followers. The oil pump has a long enough tang to pick up its drive too.ok, many thanks as usual for your patience.
Graham
#26
Posted 21 February 2012 - 11:00 AM
#27
Posted 25 February 2012 - 05:09 PM
http://www.ehow.com/...iclockwise.html
#28
Posted 25 February 2012 - 05:22 PM
