Engine Rotation Direction
27 replies to this topic
#1 grahama
grahama
  • 2,442 posts
Posted 20 February 2012 - 03:28 PM
Hi,
just as it says really. I think as you look at the timing chain it rotated clockwise, (old thread), but not sure.
I wouldn't bother but the chain I have has a link in it and needs to go on the correct way
As I look at it, chain side but right way up
As it stands it is on the wrong way round if it rotates clockwise.
Also how tight does the tensioner need to be on the chain??
Many thanks,
Graham
Edited by grahama, 20 February 2012 - 03:30 PM.
#2 JVA10L
JVA10L
  • 181 posts
Posted 20 February 2012 - 03:35 PM
Yep, clockwise.
#3 ministar
ministar
  • 835 posts
Posted 20 February 2012 - 03:38 PM
Clockwise looking at the timing cover.
Edit. beaten to it. Wouldnt post >_<
Edited by ministar, 20 February 2012 - 03:38 PM.
#4 newnham500
newnham500
  • 221 posts
Posted 20 February 2012 - 03:41 PM
oh my god sorry for the hi jack, but i have done the same to mine, blue block and head paint, sealy engine stand.
#5 newnham500
newnham500
  • 221 posts
Posted 20 February 2012 - 03:42 PM
anyway carry on, sorry
#6 grahama
grahama
  • 2,442 posts
Posted 20 February 2012 - 03:43 PM
Also, forgot...
The cam when retained by the triangular plate moves in and out by a couple of mm. Once the chain gear is on it tightens up to a midge of movement. I have looked on the mini mania vids and this seems ok, just wasn't expecting the movement before the chain gear was tightened on ???
Graham
#7 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 20 February 2012 - 05:23 PM
You are correct, the cam sprocket and triangle plate both have to be fitted and tightened up to measure endfloat. I have not memorized the exact figure but it is only about 0.003" of play you are looking for. The play you saw without the gear in place is typical.
I have not seen chains with coupling links in them. If you are worried about the direction of the chain because of the coupling link, you should be able to gently remove the clip shown in your picture and put it back on so it is facing the other direction.
Is the engine stand in your living room? It looks like a nice heater and couch behind the stand.
#8 grahama
grahama
  • 2,442 posts
Posted 20 February 2012 - 07:58 PM
Thanks for the replies.
Yea, in the conservatory which is open to the living room, wifey loves me lol. It is all clean and shiny work at the moment though so getting away with it, just !!
The end float is 12 tho, are there cam shims available as I couldn't find any online ??
Graham
#9 Pigeonto
Pigeonto
  • 973 posts
  • Local Club: ISMOC
Posted 20 February 2012 - 08:22 PM
I dont believe so,no. You'll have to get 9 thou machined from the relevant part of the sprocket so that it moves closer to the cam.That is of course assuming the triangle plate isn't worn at all.
#10 tiger99
tiger99
  • 8,584 posts
Posted 20 February 2012 - 08:55 PM
This may be a daft question, but why do you have a chain with a detachable link?
#11 Cooperman
  • 23,167 posts
Posted 20 February 2012 - 08:58 PM
All engines I've ever known rotate clockwise unless, puts on 'bus geek' hat, you have an engine out of a 1935 AEC 'Q-type' bus, which went anti-clockwise :geek:
#12 grahama
grahama
  • 2,442 posts
Posted 20 February 2012 - 09:00 PM
That's how it came !! The one I took off didn't have it but hey ho should be fine if going in the right direction.
I don't understand what to get machined ?? If I take material off the sproke twont it will make the gap larger ???
How do I do this??
#13 grahama
grahama
  • 2,442 posts
Posted 20 February 2012 - 09:19 PM
I have been reading and if the triangular plate is worn, that can affect the end float.
What thickness should they be, and if I replace with a new one wont it just push the sprocket further out away from the cam, making the endfloat bigger??
Sorry for all the questions,
Graham
#14 AndyMiniMad.
AndyMiniMad.
  • 3,295 posts
Posted 20 February 2012 - 09:39 PM
Have you torqued the cam nut yet? Or are you measuring the end float with the nut finger tight?
#15 grahama
grahama
  • 2,442 posts
Posted 20 February 2012 - 09:44 PM
No, torqued up to 65 lb/ft, the locating plate looked a 'little' worn but I don't see how a thicker / new one would help!! Shims over the end of the cam would take up the slack, but can't find any !!
Graham
