Smallbore 1098 Project Engine
23 replies to this topic
#1 project mini chris
project mini chris
    have a break, have a...
  • 1,894 posts
Posted 19 February 2012 - 05:45 PM
Well Yesterday I picked my little 1100 Engine up off of my cousin, whom I paid £50 for it (which I think is a bargain!)
It's formerly out of Old_Skool_Lews' Clubvan Estate... and has an MG Metro Cam and 40tho skimmed 12g202 cylinder head on it... and from talking to him, sounds like a really strong little engine!
The plans for it are:
Skimmed and ported 12g202 with some uprated valves (Maybe some rimflo's?)
MG Metro Cam
Duplex Double Timing Set
HIF38 Carb
Maniflow 1.75" Exhaust and LCB
My Minispeed rebuilt Gearbox with some fancy ratio's
Etc Etc...
Here are some Pics from earlier...
(Yeah thats a Morris Minor Rocker cover >_< )
and as it sits now awaiting going to the workshop to be fully stripped and built :D
Will update this soon :) Hope you all like it! :proud:
Chris
#2 oltonlad
oltonlad
  • 2,401 posts
Posted 19 February 2012 - 09:50 PM
sounds about the same spec as the 1098 that i'm doing............but i'm using a different camshaft.......and twin carbs....... ;D
its about time we got a few small bore engine projects
http://www.theminifo...oday-with-pics/
Edited by oltonlad, 19 February 2012 - 09:52 PM.
#3 Sam Walters
Sam Walters
  • 2,765 posts
Posted 19 February 2012 - 11:46 PM
Ill be playing this game soon, something a bit radical though. a 998 with a 296
#4 oltonlad
oltonlad
  • 2,401 posts
Posted 19 February 2012 - 11:49 PM
not a road engine then with that cam in a 998................ :ohno:
#5 Sam Walters
Sam Walters
  • 2,765 posts
Posted 20 February 2012 - 02:02 AM
Will be putting it in my daily driver.
#6 project mini chris
project mini chris
  • 1,894 posts
Posted 20 February 2012 - 12:32 PM
Hahaha Yeah :thumbsup: There are lots of 1098 builds at the moment... they are probably the most underrated A-Series, especially with the amount of potential they have for torque over the 1275 and 998.
Currently debating whether to get a decent set of pistons for it aswell, as i'm going to have to replace the rings for sure anyway! Should I bother with some flat tops? =]
Also I'm looking out for a Dizzy for it, If anyone could help me out with that? As I Only have A+ Ones... :lol:
#7 project mini chris
project mini chris
  • 1,894 posts
Posted 20 February 2012 - 12:41 PM
Hahaha! bit of a lumpy Idle with a 296 in a 998 dont you think? 266 would be a better profiled cam... similar to the MG Metro one... =]
#8 racingenglishcars
racingenglishcars
  • 293 posts
  • Local Club: Donn's Backyard Garage
Posted 20 February 2012 - 04:16 PM
IMHO, a 296 cam isn't easily driven on the street. You would seriously probably be happier with the 266 or 276, maybe 286.
As for flattops, I would suggest it, however proper compression ratio is a must. Somewhere between 9.5 and 10.5 is usually ok (I assume you can get 95 petrol)
I just happened to finish an excel sheet just for that purpose
http://www.4shared.c..._ratio_v11.html
It's sitting on a public server so a bit slow to download, best to use firefox. Uses excel 2007.
Edited by racingenglishcars, 20 February 2012 - 04:19 PM.
#9 oltonlad
oltonlad
  • 2,401 posts
Posted 20 February 2012 - 05:38 PM
flat top pistons are very expensive for 1098 engines (and no you cant use 998 ones!!)
theres a place in bromsgrove that do distributors (they advertise on ebay), i need one as well as ive only got A+ distributors as well
heres the link for the distributor
http://www.ebay.co.u...984.m1423.l2649
#10 project mini chris
project mini chris
  • 1,894 posts
Posted 09 September 2012 - 03:54 PM
Slight change of plan with this project!
I wont really have much time on the engine build as I'm still prepping my Mini's bodyshell ready for paint, but I got given this the other day...
It's a T2 off of a Sierra Turbo Diesel, So will be using this alongside my Metro Turbo setup I have! (Just without using the original T3!)
The Ford Turbo's have a 3 Stud Manifold, so I am going to have to get a friend to make me an Stainless Steel** Conversion plate to run it on my Metro manifold =]
Here are a few pics of some of the bit's I have to go with it...
Carb got a bit of attention!
Will also get the block pocketed and use the 12g940 head off of my 1275 :D
So thats the general idea... Was going to run my Metro T3 Turbo, but I want a sleeper ish car and dont want to cut into the bulkhead :/
Plus, a smaller turbo should work better with this engine, as it should actuate quicker at lower rpm in comparison to a T3 which is laggy =]
Chris
Edited by project mini chris, 31 October 2012 - 06:21 PM.
#11 markje
markje
  • 183 posts
Posted 13 September 2012 - 06:08 PM
woooww turboing a 1098 unit but those engines are no rpm makers
#12 oltonlad
oltonlad
  • 2,401 posts
Posted 13 September 2012 - 08:48 PM
yes, but the 1098 engines do make good torque, you dont need high rpm on a turbo engine anyway, the 1098's will rev safely to 6000rpm, thats plenty....;-)
#13 markje
markje
  • 183 posts
Posted 14 September 2012 - 01:45 PM
On that part youre right,torque is amazingly high from those units,well its interesting howw it works with a turbo,
#14 charie t
charie t
  • 3,153 posts
Posted 16 September 2012 - 10:30 AM
Alloy won't work on the manifold, especially with a turbo
Steel is used for exhausts for a reason
#15 project mini chris
project mini chris
  • 1,894 posts
Posted 19 September 2012 - 04:47 PM
Yeah I realised what I said after I posted it! :shy: Stainless Steel* Being Tig welded by a friend of mine =]
Edited by project mini chris, 19 September 2012 - 04:48 PM.
