2K Paint Advice
Posted 17 February 2012 - 06:10 PM
but is it any easier to paint with or harder than cellulose...also am i right in saying that 2 pack uses an activator and also a small amount of thinners..im hoping to paint the whole car so any help about how much paint and activator and thinners i would need...and do i still use a high build primer...and also how many coats of colour would you advice and the same question about lacquer...i know people must get sick of people like me asking basic questions but thanks for any help anybody can give...steve...
Posted 17 February 2012 - 06:14 PM
Posted 17 February 2012 - 06:17 PM
Posted 17 February 2012 - 07:09 PM
Posted 17 February 2012 - 07:49 PM
Posted 17 February 2012 - 08:01 PM
Paul.
Posted 17 February 2012 - 11:00 PM
Im in the same situation as you in terms of not being able to use 2k.
Bare metal. machine sand with 60grit to get it a good key.
zinc rich primer. You could use etch without sanding the bare metal but i like the protection zinc offers
high build (cellulose)
filler
second skim of filler (im not good with filler)
stopper
high build
probably more stopper when i spot something here
high build
top coat (cellulose)
top coat. (cellulose)
Posted 17 February 2012 - 11:05 PM
http://retrorides.pr...nt&thread=48784
I'd stick will celly, but I would shoot some sealer before I painted to prevent reactions.
I'm assuming that you're not gonna be doing a bare metal job?
Flat back and then fill as required.
Give it a coat of Bar coat to prevent reactions
MIPA do a nice combined filler and etch primer, so give it a few coats of that.
Flat it back and then top coat.
Posted 17 February 2012 - 11:12 PM
I tend not to use bar coat. I always to back to the good old steel.
But honestly this takes forever and a day to build it back up.
Bar coat does work well. It only needs to be a thin coat and needs to be even.
Posted 18 February 2012 - 04:48 PM
gerson or 3m make excellent masks that you can paint 2k paints with for up to 40hrs for about 25 quid. i have used both for years and they are very good. had no probs. and the suits are about £10 made by du pont.
and also once given a coat of paint your not goin to stay in the garage with the fumes are you?? well hopefully not!!
Posted 18 February 2012 - 05:05 PM
Posted 18 February 2012 - 08:32 PM
etch primer (upol acid 8) just because it dries quicker than 2k
hb body spray on filler/putty- if you have a few repairs and want them dead straight its excellent stuff, if not dont use it. flat with p180
2k primer-flat all the way up to p800 wed n dry
2k paint- as for amount of coats really depends on how u put the stuff on, because everyone is different with a spray gun. but very similar to cellulose get as much as you want on there, and flat the hell out of it for a wicked shine and finish. bout 4-5 coats should do.
2k paint mix 2:1 with hardener and a bit of 2k thinner if you want 5-10%
there should be loads of walkthroughs on here mate
Posted 19 February 2012 - 12:24 AM
Phone up 3m and ask them.
Posted 19 February 2012 - 07:13 PM
Posted 19 February 2012 - 09:08 PM
And particularly the experiences of somebody who did not wear the right safety gear... http://www.mig-weldi...ead.php?t=14051
He's still alive but permanently affected by the stuf!!!!
Paul.
