Clutch/flywheel Bolt Getting Lose
Posted 14 February 2012 - 08:34 PM
and put it back on, had a guy up the road who deals with minis to come and close it, put it all back together, same thing happend again come lose clutch pedal hard then flywheel getting lose , waht causes this why ? thanks
Posted 14 February 2012 - 08:37 PM
Posted 14 February 2012 - 08:39 PM
Posted 14 February 2012 - 09:06 PM
All look goodwhat's the crank tail like?
Posted 14 February 2012 - 10:55 PM
The key can not transmit dynamic load, which is all done by the tight fit of the taper, so it really must be tight.
Posted 15 February 2012 - 12:26 AM
Posted 15 February 2012 - 08:36 AM
Posted 15 February 2012 - 12:22 PM
Posted 15 February 2012 - 12:29 PM
Posted 15 February 2012 - 03:07 PM
The taper MUST be a good lapped fit, and the bolt MUST be torqued up correctly, or failure is inevitable. All the Loctite in the world will not help. And please, no Loctite on the taper.
There are far too many instances of this problem on the forum, and this one seems to have been attended to by a supposed expert, who isn't. That makes me very sad.
Posted 15 February 2012 - 03:10 PM
Posted 15 February 2012 - 04:57 PM
It is all very sad and unnecessary, and a very good reason for advocating the need to do things correctly, to avoid trouble in the future.
Hopefully this particular car will respond to a lap and retorque, and not need a crankshaft and flywheel.
Posted 15 February 2012 - 07:34 PM
I heat the flywheel and fit it hot, tightening the bolt straight away, thus shrinking the taper onto the tail of the crank. It's a right ball ache to get the thing back off though. There are all sorts of weird and wonderfull ways of tightening the flywheel joint, but I don't think the factory would have had the time do do these.
Posted 15 February 2012 - 10:33 PM
My reservations about fitting them hot are based on another recent thread, where the flywheel could not be removed. It may be necessary here as a last resort, as there may be so much wear that it needs to be both lapped and fitted hot.
If fitting hot, it may be advisable to drill and tap the holes for the flywheel puller to the next size up and modify your puller accordingly, in the expectation that getting it off again will be difficult. Easily done with the flywheel on the bench, not much fun in the car.
I like to aim to anticipate and avoid creating problems for the future. Sometimes you can, sometimes you can only do the best with what you have. In this case it may be that the flywheel can be fitted tightly, but will never come off again. If it is not a rare and expensive version of the A series, that risk may be acceptable.
Posted 16 February 2012 - 08:15 AM
