1972 Mini Clubman Estate [Project Stitch]
129 replies to this topic
#106 brum,brum,mike
brum,brum,mike
  • Just Joined
  • 554 posts
Posted 16 September 2012 - 11:01 AM
looking good, love the colour.
#107 dezshearer
dezshearer
  • 441 posts
  • Local Club: mini-chat.co.uk
Posted 16 September 2012 - 11:16 AM
Top notch welding and repairs there! Great colour too!
#108 mini danny
mini danny
    I am a mini daddy.
  • 5,229 posts
Posted 16 September 2012 - 11:33 AM
Errrrrrmmm im speechless there is some absolutely amazing welding going on and some very good dressing to the weld can't wait to see her all finished
Danny
#109 asahartz
asahartz
  • 227 posts
Posted 04 November 2012 - 10:40 PM
I know I've been quiet on this thread, but I have been working on the car. It's just that there's not been much to see! Filler takes so long to get right when you want a car to be as good as this.
So here's the filler:
Then I stripped out the remaining bulkhead components, chopped out the radiator cowling, and painted the rest of the engine bay:
Next I spent about a day fitting the Rover 200 rear seatbelts. I'm putting a full guide to this in the CER Technical section, but here's the finished article:
Then I sprayed 2k primer all over the car.
Today I've flatted the whole car back, taking out a lot of imperfections, and finding a few areas that needed a bit more filler. Then put another coat of primer on top, ready to flat it all again. It's not far off being ready for a bit of topcoat at last!
#110 MentalMini
MentalMini
  • 17 posts
Posted 05 November 2012 - 11:08 PM
i wish i had a garage to get stuck into my clubby estate - nice work
#111 asahartz
asahartz
  • 227 posts
Posted 16 November 2012 - 11:28 PM
Well I've had chance to at least paint the inside. The floor is brush-painted in Rustoleum, but the rest is sprayed in 2-pack topcoat - and the colours are so close you can hardly tell the difference! Second coat went on tonight.
That is one sexy colour! It's slightly darker in the flesh.
#112 HollyBaby
HollyBaby
  • 109 posts
  • Local Club: -
Posted 02 December 2012 - 07:30 PM
I have played the parts fairy and visited my dad bearing bags of shiny bits from Huddersfield Spares...
Fast road coil spring set, ProTech aluminium billet shocks, HiLos, knuckle joints, adjustable rear camber brackets, adjustable bottom arms (to go with the adjustable tie rods in yesterday's parts boxes), poly bushes, Wood & Picket style arches, Custom Consoles dash, and Tex mirrors!
To quote dad: "I'd better get out there and do some more paintwork!"
Dad flatted & prepped the roof and got ready to spray.
The first coat usually takes more paint than you expect, so he mixed up a little more than he thought he needed...
Having sprayed it realised he had mixed up far to much paint! So thought "Sod it - spray it on the car."
And here it is!
#113 blue blood
blue blood
  • 806 posts
Posted 02 December 2012 - 09:33 PM
Looks good :)
blue
#114 L. Brown
L. Brown
  • 22 posts
Posted 02 December 2012 - 09:39 PM
Nice!!
#115 ClubbyAsh
ClubbyAsh
  • 149 posts
Posted 16 January 2013 - 11:22 AM
Loving that colour, everone with any sense knows blue is by far the best! :shifty:
#116 Minilover1.3
Minilover1.3
  • 216 posts
Posted 16 January 2013 - 01:54 PM
Great thread. Jus read from start to finish. Wish I had the skill and know how to do what ur doin!
#117 Andymini
Andymini
  • 48 posts
Posted 16 January 2013 - 02:32 PM
is it just me or can no one else see any of the pictures?
#118 Minidarren83
Minidarren83
  • 1,207 posts
Posted 16 January 2013 - 03:43 PM
Just you
#119 asahartz
asahartz
  • 227 posts
Posted 26 January 2013 - 08:15 PM
Well although I got a couple more coats on, that was about how I left it looking on Christmas Eve. Since the new year the weather has not been good enough for painting - too cold and in particular too damp; even when I heat the garage I get condensation.
So I turned my attention to the subframe. Last weekend I cleared up the other end of the garage and cleaned off the subframe. I also found I needed to modify the subframe jig that I'd fabricated - Adam said it wasn't tall enough and when I started work I found he was right. So I welded in an extra 60mm and refabricated the front mounts.
Here's the subframe bolted into the jig:
First job was to weld in the support strut between the towers.
First cut is the deepest...
Then I fabricated up the new front bar, with a slight curve to match the Clubman front panel - this bar will be just below the bottom edge of the front panel. There are two sections of 6mm flat bar to bolt this to the front panel mountings.
To make room for the K-series driveshafts, the bottom front of the towers was cut away. The old bottom arm bolts will be discarded, new mounts welded in and a new shorter bolt fitted. Having welded two more sections of flat bar to the bottom face of the frame below the towers, just under the bottom arm mountings, I welded in the nearside bottom leg.
Which is as far as I got today. More to come...
Edited by asahartz, 26 January 2013 - 11:02 PM.
#120 asahartz
asahartz
  • 227 posts
Posted 27 January 2013 - 06:19 PM
Spent another hour in the garage after getting back from Bingley. Managed to get the other bottom leg done (I felt I'd left a job half-done!)
I'll get the top legs done next week.
