Servo Leak?
12 replies to this topic
#1 callyspoy
callyspoy
  • 110 posts
Posted 11 February 2012 - 05:17 PM
Aye up, i went to fit a new grommet for the vacuum on the servo and noticed that there was liquid in the servo. Had a look and it is brake fluid (which i did presume it was!)
The brake fluid hasn't gone down at all since i bought the car in October, but the brakes have always felt a bit unassisted (like my old Herald i guess).
I guessed it was to do the vacuum, but now thinking i may have to shell out for a rebuild kit, just wondering if it could be something simple? I assume there shouldn't be any fluid floating around in the servo?!
Thoughts please ladies and gents!
#2 callyspoy
callyspoy
  • 110 posts
Posted 11 February 2012 - 05:39 PM
Whoops, it's an '89 Mayfair by the way with inbuilt servo/master cylinder (as in NOT remote)
#3 bmcecosse
bmcecosse
  • 9,699 posts
Posted 11 February 2012 - 08:15 PM
Just get rid of the servo - small car like that doesn't NEED a servo..... I never ran servo on any of my Minis...... There should definitely NOT be any fluid in the servo casing.....
#4 callyspoy
callyspoy
  • 110 posts
Posted 11 February 2012 - 09:38 PM
To be honest with you, i wouldn't have a problem doing that, especially as it's a nuisance there!
What parts would i need though if i were to remove it? MOT at the start of March and i don't really want to be paying out too much before that!!
#5 bmcecosse
bmcecosse
  • 9,699 posts
Posted 12 February 2012 - 12:23 AM
I guess you would need to change to a non-servo master cylinder. My advice also -get rid of the ghastly taper nose pressure regulating valve, and fit an early style pressure limiting valve in the feed to the rear brakes. Fit this up front on the bulkhead - where it's easily accessed to allow 'fine tuning' of the pressure spring......
#6 MiniHarriett<3
MiniHarriett<3
  • 159 posts
  • Local Club: TMF & J19
Posted 12 February 2012 - 08:09 AM
Hello!!
my friend just let my into know your brake master cylinder is broken, i bought one for my car and was supplied the cylinder meant for servo leaving me stuck with the wrong part.
i paid £100 for it and selling it for just £65 + p&p Brand new in box :)
http://www.ebay.co.u...984.m1555.l2649
hope i can be of some help :D X
#7 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 12 February 2012 - 02:46 PM
Sale stuff isn't normally allowed in the Tech Section but I will leave this one here since you are answering a specific request for info by the OP.
#8 callyspoy
callyspoy
  • 110 posts
Posted 04 March 2012 - 07:58 PM
Right folks, i am feeling more and more like i will inevitably be changing the seals in the servo.
But...
I am still swaying towards removing the servo and fitting a Non servo MC (the later type)
My question is, what do i NEED to change in order to do the swap? I'm not messing around with other stuff that isn't neccessary, just want to know if it is a bolt off, bolt on change?
#9 bmcecosse
bmcecosse
  • 9,699 posts
Posted 04 March 2012 - 08:22 PM
I guess you need a non-servo master cylinder - and seriously - dump that ghastly taper nose valve.........
#10 freshairmini
freshairmini
  • 1,718 posts
Posted 04 March 2012 - 10:05 PM
If it was fitted with a servo surely it would need it to pass an mot?
(null)
#11 bmcecosse
bmcecosse
  • 9,699 posts
Posted 04 March 2012 - 11:48 PM
No! :unsure:
#12 Ethel
  • 25,922 posts
Posted 05 March 2012 - 12:04 AM
Not for an MoT,but probably needed to keep your insurance valid. The problem isn't the serv, it's the master cylinder; repairing or replacing the one you have will be the cheapest & simplest option. If you don't want a servo just disconnect the vacuum pipe
#13 callyspoy
callyspoy
  • 110 posts
Posted 05 March 2012 - 01:07 AM
Ethel, yes, the repair kit is one of the options, it's just the cost of a repair kit is rather expensive. So i thought, for the sake of the effort, just buy a brand new non servo MC and do that as it would also tidy up the engine bay.
Oh curse my indecision!
