Haynes I did state Haynes in my first reply. Of course you'll now call it the Haynes book of lies :) But I'd imagine Haynes mini manual as been out that long I would think they would have revised pretty much any mistakes out of it by now.
To be fair though I found what I presume is a workshop manual online and it doesn't mention the plain washer
Although Cowboy does mention update bullitens so maybe they added it to those ??
2. Fit hub bearing water shield onto drive shaft as
shown:
’A’ = 6 mm approximately.
3. Lubricate end of drive shaft and fit to inboard
joint.
NOTE: Ensure shaft is securely retained
by joint.
4. Clean front hub ball joints and mating faces of
suspension arms.
5. Fit front hub to drive shaft and engage upper
and lower ball joints on suspension arms.
6. Fit nuts and washers securing suspension
arms to front hub and tighten to 52 Nm.
7. Connect steering rack track rod end to front
hub, fit nut and tighten to 30 Nm.
8. Clean front brake disc.
9. Fit brake caliper to front hub.
10. Fit 2 bolts and washers securing brake caliper
11. Fit road wheel.
12. Position jack beneath lower suspension arm
and raise front suspension.
13. Remove wedge between suspension arm and
subframe.
14. Position rebound rubber and secure with
screw.
15. Remove jack from beneath suspension arm.
16. Remove stand(s) and lower vehicle.
17. Fit split collar and tighten hub nut to 260 Nm.
18. Align nut to next
Edited by lrostoke, 13 February 2012 - 10:50 AM.
