Rover Mini Key Fob Replacement
5 replies to this topic
#1 richand26mhz
richand26mhz
  • 42 posts
Posted 09 February 2012 - 12:09 PM
has anyone replaced one of these? On my 97 cooper i only have 1 set of keys.
I'm looking to get another for back up. How easy you sync these with the car?
Rich
#2 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 09 February 2012 - 12:12 PM
Do you know what you get if you type the title of this thread into Google?
http://www.remotekey.co.uk/cars/rover/
#3 blakie
blakie
  • 1,030 posts
Posted 09 February 2012 - 06:15 PM
Do you have a local rover garage with the equipment? The dealer I work at has all the equipment required to supply and programe a new fob and key if required but were a bit far from you i think.
www.kernahanservice.co.uk
blakie
#4 matt615
matt615
  • 923 posts
Posted 09 February 2012 - 06:43 PM
You can get this done at your local Timpsons branch, they stock and program Rover key fobs.
However when I enquired about the cost, they said it was £125, including getting an ignition key cut. When I said no thanks and started to walk ok they said "ok we'll do it for £110". Still too much for me though so I didn't bother getting one.
I have seen 'learning fobs' on e bay a few times, for £10 - £20. You supposedly put them next to your original fob, press a button on the original fob and on the new fob simultaneously, and it programs the new fob. That's probably the cheapest way to do it, if they work.
#5 richand26mhz
richand26mhz
  • 42 posts
Posted 09 February 2012 - 06:53 PM
Thanks i will look into it, I have seen the remote key site before on GOOGLE and wanted to know if it was expensive, Seems ok compared to Timpsons,
#6 icklemini
icklemini
  • 2,982 posts
Posted 09 February 2012 - 08:16 PM
i can do it in Northampton...
