I have just fitted my engine and got it running, after getting oil pressure, fitting the plugs, it fired up, got it running sweet as a nut!
Started it up this morning, no problems, warmed up and ticked over really cleanly and rev'ed with no issues. Then as we (me and dad) fitted the Lucas electronic ignition, we fired it up, was perfect.
There was one wire coming out of the loom which was black and white with a male connector, which has lost its masking tape label and dont know where it goes, If i touch it on the coil - it illuminated the oil pressure and battery light with the ignition off?
Also I think this wire is for the Rev Counter as this is not working. We tried it on the body to see if it was earth and it just sparked and got hot.. My coil has 3 terminals 2 + positive and 1 - negative, after some reading about it seems this wire should be on the negative (-) coil terminal, is there a missing terminal on my coil ?
My coil..
and the wire that sparked when touched the body (taped up to stop it touching the body)
I have looked in the haynes manual and I struggle to understand wiring diagrams
Car Spec:
1989 Austin Mini Mayfair
998cc
59d4 Distributor
Lucas Electronic Ignition Kit
Any help is greatly appriciated..
Dan..
