How To Remove The Windscreen?
Posted 31 January 2012 - 06:36 PM
I want to remove the windscreen on my 2000 Rover MPi, and possible replace the scuttle panel.
Are there any guides on how to do this?
Thanks!
Ben
Posted 31 January 2012 - 06:55 PM
Posted 31 January 2012 - 06:56 PM
Posted 31 January 2012 - 07:04 PM
Posted 31 January 2012 - 07:08 PM
Posted 31 January 2012 - 07:09 PM
Ordered a Haynes Manual. Looks like it will be of great help with my Mini!
Deffo mate! As miniluke said though it wont be of any help with panel work and the scuttle bit your after.. try searching on here for it :)
Posted 31 January 2012 - 07:10 PM
I just want to inspect the scuttle, not necessarily replace it.
In that case (speaking from experience
Posted 31 January 2012 - 07:24 PM
The replacement might seal better so the rust may not come back as quick
Posted 31 January 2012 - 07:27 PM
Posted 31 January 2012 - 07:32 PM
Posted 31 January 2012 - 07:35 PM
Posted 31 January 2012 - 08:22 PM
Posted 31 January 2012 - 08:30 PM
The scuttle will definitely need replacing as there is a lot of rust bubbling underneath it..
Posted 31 January 2012 - 08:44 PM
It's easy to remove the screen, just pull out the chrome locking strip, then push the screen from the inside.
The front wings will need to be removed to fit the scuttle and possibly the lower screen rail.
Make sure you measure the windscreen gap in about 3 places before cutting metal as the screen aperture must be exactly the same after repair.
