Changing Cones Without A Compressor
Posted 31 January 2012 - 06:11 PM
Am doing my Sus soon and changing the cones to Smootha ride ones, I have heard you can do the job without a cone compressor. Is that true? What do you have to do differently? Is it ridiculously harder without the tool?
Sorry for all the questions
Thanks in advance
Dave
Posted 31 January 2012 - 06:36 PM
they cost much anyway...
Posted 31 January 2012 - 06:40 PM
Posted 31 January 2012 - 07:11 PM
Posted 31 January 2012 - 07:18 PM
I wouldn't have thought you'd be able to adjust hi-los enough that you'd be able to just push the new cone in but I've never used them so I don't really know.
Posted 31 January 2012 - 07:21 PM
Posted 04 February 2012 - 07:12 PM
I changed to hi los and from memory had them adjusted pretty low to get them in up front. This was with a compressed new cone fitted.
Posted 04 February 2012 - 08:02 PM
Posted 04 February 2012 - 08:07 PM
Posted 04 February 2012 - 08:15 PM
Mine sits in the bottom of my toolbox, I pull it out occasionally for suspension work, and the cost has long since been forgotten.
Posted 04 February 2012 - 08:20 PM
Posted 04 February 2012 - 11:13 PM
Chris
Posted 13 May 2012 - 08:46 AM
Posted 13 May 2012 - 10:10 AM
I've been wanting to do it on the cheap too and from what I have read you could make your own out of a threaded bar but because it will end up under tension then you have to use a hardened bar which either costs nearly as much as the dedicated tool, or is a lot of hastle to harden one. The other option is find someone local that will lend you one, or someone that will post one under the condition that you post it back when done!
I've seen it in flash, it is made of a old steering rack rod...to be honest, buy a proper cone compressor, makes the job far easier and safer.
Posted 13 May 2012 - 05:12 PM
You cut throughthe trumpet, which will still have pressure on it.. As you cut through it will collapse onto your cutting disc. The angle grinder will jam, your arm will let go, the angle grinder will eat straight through your face. If you are lucky to survive, you probably won't be able to drive your mini again anyway, as you will likely be blind, or have serious health problems.
Don't try and skimp for £20. Buy the tool, keep you and others safe. I'd say that shanging cones is a pretty dangerous job. I nearly lost my fingers the first time I changed them. This was through not using the correct tool, and the threads stripped.
Be safe!
