12" Boxed Pioneer Sub And Vibe Slick A3 Amp
5 replies to this topic
#1 mike.
mike.
  • 6,176 posts
Posted 27 January 2012 - 10:52 PM
Re advertising these 2 as i'll be taking them to bingley this weekend if anyone wants them.
The sub is a 12" pioneer sub, with grill and sub box. The box is a good size/shape for a mini boot as it has a sloped back to it.
Not sure on exact spec of sub but at a guess its around 400w RMS and 1000-1200w max. Good quality sub, I bought it off a friend who had it in his golf running off a big mono amp and it was silly loud if you turned up the gain, rattles the panels off if you want it to. Turn it down to a sensible level though and its a good all round sub, good quality punchy bass.
Looking for £40 for this.
Then the amp, this is a vibe slick A3 amp. This is a great amp, its a class A-B amp, 4 channel, 1300w max. This gives 100w RMS per channel at 4 Ohm's to run 2 sets of high end components or, or 2 of the 4 channels can be bridged to give 2 x 100w RMS channels and 1 at 325w RMS to power a sub. So a good choice to power a set of nice components and a sub.
It comes without the end caps, but these are just to cover the wires and do not effect the function of the amp.
I'm looking for £50 for this.
Can take both to bingley if the interest is there, if not collection only.
#2 mike.
mike.
  • 6,176 posts
Posted 28 January 2012 - 02:47 PM
£30 for the sub?
#3 h4wx1e
h4wx1e
  • 553 posts
  • Local Club: sutton mini club
Posted 28 January 2012 - 04:45 PM
Would it be possible to run 2 subs and a set of 6x9s with the amp mate? Im running 2 amps at the mo both been vibe so i know their pretty good for what I'm after but would prefer just running one.
Thanks David
#4 mike.
mike.
  • 6,176 posts
Posted 28 January 2012 - 05:55 PM
Depends how big the subs are.
Each channel gives 100w RMS and 325w max.
If your running 2 small subs which will run ok off 100w RMS then yeah that'd work fine. 1 channel per sub and then 2 left over to run the 6x9's.
If its 2 big subs, really you probably want at least 300w RMS each for them, which this amp will do, it'll give 2 x 325w RMS but you won't have any channels left for 6x9's after that.
#5 h4wx1e
h4wx1e
  • 553 posts
Posted 28 January 2012 - 07:34 PM
Sound they are only 8inch Inphase subs rated at 1000 w dnt know rms thou but should be fine. I have the a3 but only 2 channel at the mo and a slick mono So I have the ends, would you be willing to take 40 for the amp and Im going bingley tomorrow so can grab them their?
#6 mike.
mike.
  • 6,176 posts
Posted 28 January 2012 - 07:38 PM
Go on then, PM you now
