Help! I Shrank My Bonnet!
566 replies to this topic
#331 olds_kool_lews
olds_kool_lews
  • 3,601 posts
Posted 29 July 2012 - 06:49 PM
started on the independent front suspension today, just need to make the bracket for the shock absorbers to mount to and a way of bolting the wheels on (already sussed this)
#332 DaveJH
DaveJH
  • 393 posts
Posted 29 July 2012 - 11:05 PM
Wow, this is awesome - can't believe I've not seen this before! Add me to the list of impatient fans :proud:
#333 olds_kool_lews
olds_kool_lews
  • 3,601 posts
Posted 04 August 2012 - 11:49 AM
The rear axle is away at an engineering shop having thread cut into it to allow me to mount the wheels, then thats all the back finished, ive also managed to sort some wheels out for the front in the way of pushchair wheels from a stroller lol right size, width n style, just need to paint the centres n get them mounted on my basic yet functional steering set up
#334 olds_kool_lews
olds_kool_lews
  • 3,601 posts
Posted 04 August 2012 - 05:51 PM
its now rolling (on the front anyways, the rear axle is away for machining) heres a quick pic of what stage im at now :proud:
#335 brad-the-bear
brad-the-bear
  • 1,114 posts
Posted 04 August 2012 - 05:55 PM
O_O O_O :w00t:
#336 olds_kool_lews
olds_kool_lews
  • 3,601 posts
Posted 04 August 2012 - 06:00 PM
Now that the front wheels are mounted, i can start again with a front end, im thinking possibly making a 1/4 scale mould and make a fibreglass front end, might be easier than trying to form the wings/front panel from steel
#337 DaveJH
DaveJH
  • 393 posts
Posted 05 August 2012 - 11:21 AM
Love it! Having a mould could come in useful for reproduction :shifty:
#338 olds_kool_lews
olds_kool_lews
  • 3,601 posts
Posted 06 August 2012 - 06:02 PM
Rear axle is back from the machine shop, wheels on and bolted up, perfect fit ;)
#339 leigh21
leigh21
  • 319 posts
Posted 06 August 2012 - 06:40 PM
Pics? I cant wait til you get to the testing of servo's etc, Im very interested in doing something like this myself. Keep up the good work!
#340 leigh21
leigh21
  • 319 posts
Posted 09 August 2012 - 07:15 PM
Got anymore work done lewis? Im starting to get impatient again!
#341 olds_kool_lews
olds_kool_lews
  • 3,601 posts
Posted 09 August 2012 - 10:10 PM
Lol I had to sort some better fitting fixings for the rear wheels and found some perfect ones on an old bmx wheel lol so it's on all 4 wheels now, just need to sort the front shock mounts out and make a brace bar to attach the top shock mounts to, so it can sit properly and I can begin to build the front end, will get pics up tomorrow :P
#342 olds_kool_lews
olds_kool_lews
  • 3,601 posts
Posted 13 August 2012 - 11:40 AM
Started the front end finally, im going to make 1/4 scale fibreglass front end so so far i have got my hands on a couple of large sheets of oasis foam, which i glued together, cut in half, glued together and so on until i had 1 big block to work with, marked out the front end and got chopping/sanding/shaping/fillering to make a plug from which ill make a negative mould from, which will then i can make a positive ( being the new fibreglass front end) lets see how this 1 works out lol
#343 leigh21
leigh21
  • 319 posts
Posted 13 August 2012 - 03:46 PM
you got any pics of your plug?
#344 olds_kool_lews
olds_kool_lews
  • 3,601 posts
Posted 15 August 2012 - 08:42 PM
Its a work in progress, only the 2nd coat of filler to shape but its getting there!
#345 SamMayfair1996
SamMayfair1996
  • 193 posts
Posted 15 August 2012 - 09:04 PM
This is fricking awesome, keep up the good work. :)
