Help! I Shrank My Bonnet!
#316
Posted 24 June 2012 - 02:08 PM
#317
Posted 25 June 2012 - 10:37 PM
#318
Posted 26 June 2012 - 03:32 PM
#319
Posted 26 June 2012 - 05:40 PM
good luck
michael
#320
Posted 06 July 2012 - 10:29 PM
#321
Posted 06 July 2012 - 11:22 PM
I need to turn the ends down on the axle to fit the hub nuts and bearings as the axle is exactly the same diameter as the bearings/hub nuts, so wont go on easily, once i got the axle finished, i can mount the engine and sort the chain length, then finish the bodywork, then sort the front end steering out and electrics, then dismantle, Paint n reassemble! Sorted!
N thanks for the comments guys, ill try get some progress pics up soon ;)
can you not freeze spray the axle ends to ever so slightly reduce the diameter of the axle, and use a blow torch or heat gun to heat the bearing to slightly increase the internal diameter size in order to then get the bearing on, in a sense heat shrinking the bearing in place........ it wont come off thats for sure......
#322
Posted 16 July 2012 - 11:22 AM
#323
Posted 19 July 2012 - 12:09 PM
#324
Posted 19 July 2012 - 12:58 PM
#325
Posted 27 July 2012 - 07:02 PM
Having decided that the original chassis was too heavy, i decided to start again and make a ladder frame chassis, which made a hell of a difference! it also gave me a new mounting point for the rear bearing block (which just so happens to be the center of a minimoto wheel!!) ;) i made the chassis out of 10mm box section, still have a few mods to do but the rear end set up is nearly complete! Here's pics...
1st look of the chassis with the pick up bed welded on
few modifications that i had to do to get the mini moto wheel centre to fit...
the black lines are to show where i needed to make some brackets so i have clearance for the chain sprocket
brackets made and test fitted, still need to weld them in...
how it will kinda look when set up
the rear axle looks bent (its not, its 2 seperate bars to show how it'll look lol)
#326
Posted 27 July 2012 - 07:35 PM
#327
Posted 27 July 2012 - 07:42 PM
#328
Posted 28 July 2012 - 08:07 AM
#329
Posted 28 July 2012 - 10:17 PM
I like that you've used a liquorice allsort as part of this build!
#330
Posted 29 July 2012 - 11:50 AM
