Electric Power Steering?
Posted 25 January 2012 - 01:01 PM
I'm quite sure that I'm up to figuring all this out on my own. I'm also sure that my successful installation would amount to either both front wheels turning in opposite directions or the left rear wheel acting like it was on a swivel.
I can follow reasonable directions, and do some not too crazy modifications but not invent systems...so a kit is the only way this would work for me.
Posted 25 January 2012 - 01:45 PM
Posted 25 January 2012 - 02:01 PM
But seriously for the cost of it, really, really isnt worth it..
Posted 25 January 2012 - 05:02 PM
Posted 25 January 2012 - 05:06 PM
There are vauxhalls that use electric power steering units and I know a few people have used them for the conversion. You can buy a kit but they are expensive! It would probably be cheaper to pay someone to modify a vaux unit.
Posted 25 January 2012 - 05:21 PM
look at the vauxhall stuff.
Posted 25 January 2012 - 05:23 PM
Just mentioned that from cost point seems drastic, but hey if they want to do it...go for it..
Edited by cooperdan, 25 January 2012 - 05:24 PM.
Posted 25 January 2012 - 05:25 PM
If you were to talk to any engineer within a motor manufacturing company they will tell you just how difficult it is to find a balance between "easy" or "light" steering which is useful when in carparks etc and "weighty" steering that lets you feel the road and that gives you confidence to chuck a car into a corner and know that it will stick.
But as said above, if you want it, go for it. Just remember to take note of the pros and cons
Edited by jamesmpi, 25 January 2012 - 05:27 PM.
Posted 25 January 2012 - 05:27 PM
But it is worth pointing out that if you do decide to go down the route of installing a power steering kit, then you do run the risk of loosing the unique "feeling" that you can from a mini thanks to its simplistic set up.
Touche.....
Posted 25 January 2012 - 05:31 PM
just my 2 pence worth
Posted 25 January 2012 - 05:58 PM
Posted 25 January 2012 - 06:00 PM
buts its totally up to you, your car, you do what you want! (power steering is still crap tho)
Posted 25 January 2012 - 06:07 PM
Posted 25 January 2012 - 06:08 PM
here ya go the other thread about it
http://www.theminifo...power-steering/
Posted 25 January 2012 - 06:58 PM
It seems to happen every time one of these threads comes up, it baffles me.
Apparently shorties, convertibles, engine swaps and air conditioning are all okay but not power assisted steering.
Anyway to answer the original question, it seems most people who don't get burnt at the stake tend to fit Vauxhall Corsa PAS as it's cheap and readily available.
