Crabbing? And How To Fix It?
Posted 21 January 2012 - 09:22 PM
im been folled by a RAC man and also my dad, they both say my mini is crabbing. the rear is further left than the front so you can see the drivers door when driving
ive looked on here and found some bits about subframe alignment or radius arms
it hasnt had a accident thats reported so i didnt think it could be a twisted subframe
if it is one of the above, would it be a easy fix? like realigning the subframe or a simple change of arm.. or are we talking about a specialist job?
many thanks
Posted 21 January 2012 - 09:29 PM
Posted 21 January 2012 - 09:31 PM
Posted 21 January 2012 - 10:22 PM
Posted 21 January 2012 - 11:11 PM
Pattern rear subframe replacement?
Posted 21 January 2012 - 11:19 PM
if you look down at the rear wheels from the top of the car the wheels should "toe out" towards the rear, in other words you should be able to see more of the tyre at the back of the wheel looking down
'toe out' is where the front of the tyre is sticking out :)
Posted 21 January 2012 - 11:25 PM
Posted 21 January 2012 - 11:29 PM
Posted 22 January 2012 - 12:40 AM
Posted 22 January 2012 - 11:58 AM
if the radius arms are bend will i be able to see the actual bend?
and if the latter that the sub frame is out how will i know that?
Posted 22 January 2012 - 12:04 PM
Posted 22 January 2012 - 05:21 PM
You'll not be able to see the toe-in on the rear by eye.
Check that it looks the same both sides. If it drives, holds the road and handles OK, don't worry about it too much, but if not, get it professionally checked and set up. The front wheels should toe-out 1 mm and the rears MUST toe-in between 1 mm and 2 mm.
Posted 25 January 2012 - 04:34 PM
or was that just due to the speed?
