Weber 45 On A 3.5Inch Manifold
18 replies to this topic
#16 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 23 December 2012 - 11:30 PM
I'd be interested in seeing a picture of it as well, thanks
#17 Dusky
Dusky
  • 5,322 posts
Posted 10 December 2014 - 02:31 PM
This is my Weber 40 setup taken off the head as you see it,sorry it has,nt been on the car for a while as my head is being modded and i plan to run a SU HIF44 on a minispares inlet with an MED stub stack and ITG filter setup.
The Weber was only thirsty when you started to get to 5/6500rpm but it really growls when opened up.
I have put it in the for sale section as i cannot see me using it again and i would think it would be more use on another vehicle as stuck on a shelf!!.
But MPG wise it did,nt seem that bad if you were steady away.
did this need bulkhead mods?
#18 mingy
mingy
  • 930 posts
Posted 12 December 2014 - 08:20 PM
Yes, the mini had the bulkhead section cut out, i believe in the early days when a standard mini was converted to a rally spec car they cut the battery box out of the boot section and welded it into the bulkhead to accomodate a weber 40/45.
The battery box area was plated up and the battery was secured in a cradle in the boot.
#19 Dusky
Dusky
  • 5,322 posts
Posted 12 December 2014 - 08:36 PM
Darn :P  Was it a 63mm filter?? :P
Im inneed of one that will fit without mods, I'm not allowed to do bulkhead mods sadly
