Calling All Low Mini's On 10's
137 replies to this topic
#31 Carlzilla
Carlzilla
  • 1,907 posts
  • Local Club: Splinters Mini Club
Posted 13 January 2012 - 09:58 PM
Oh and excuse the brake dust on the fronts, they normally look like this:
http://a1.sphotos.ak...7_3749492_n.jpg
#32 conlad
conlad
    Previously known as ct16mini.
  • 2,054 posts
  • Local Club: Hilltop Minis
Posted 13 January 2012 - 10:06 PM
very sexy carlzilla ;)
i do like the look of revo's to be honest, just finding some 10x6's that are cheap with tyres haha....
:whistling: anyone?
#33 mk1leg
mk1leg
  • 9,343 posts
Posted 13 January 2012 - 10:15 PM
i love your mini mk1leg!
Thanks very much......................took 4 years to complete.................see build thread.............
http://www.theminiforum.co.uk/forums/topic/57591-all-my-own-work/page__st__15
#34 richw911
richw911
  • 2,084 posts
Posted 13 January 2012 - 10:20 PM
That looks great mab, as do all the others on tens :D What sort of fuel filler caps are they?
I have a set of tens in the garage that I'm continually tempted to use on my mpi.
Thanks, the stainless fuel filler caps were a classic pentagon shape made by Waso in the 1960's and 70's.........I bought the pair with matching keys brand new in the late 1970's but they still turn up on ebay from time to time. Someone should reproduce them!
I also went from 13's to 10's and kept my W&P arches and they fit fine, the front wings were originally cut to suit the 13's but the clearance was useful for the wide 6x10's on full steering lock.
Thanks for the info i have one of these on mine :shades:
#35 ryan22_lgm
ryan22_lgm
  • 1,478 posts
Posted 13 January 2012 - 11:27 PM
mines quite low bout finger between rear wheel and arch and 2 and a half between front need to take out the adjusters on the hilos to bring the front down more :)
#36 Broomer
Broomer
  • 1,771 posts
Posted 13 January 2012 - 11:29 PM
Broomer, are your rear arches tubbed? Whats your suspension set-up like?
Yes sir, my arches are tubbed, running gaz lowered shocks with hilos. its pretty low...
has not scrubbed once since being tubbed though.
#37 conlad
conlad
  • 2,054 posts
Posted 14 January 2012 - 09:03 AM
Hmm, its very low, I like!
How much was it to tub?
#38 conlad
conlad
  • 2,054 posts
Posted 14 January 2012 - 09:06 AM
ryan22, mate your mini is awesome, yours and broomers are the ones making me want to do 10's!
#39 Broomer
Broomer
  • 1,771 posts
Posted 14 January 2012 - 09:17 AM
about 4 hours of my time and some sheet of steel.....
#40 conlad
conlad
  • 2,054 posts
Posted 14 January 2012 - 09:19 AM
'cheap' then? ;) What would I be looking at if I took it to someone would you say?
#41 Broomer
Broomer
  • 1,771 posts
Posted 14 January 2012 - 09:25 AM
200-300? also depends on how much of the paint they damage during the process.
i like the way mine doesnt look massively low from a distance because the arches are just raised the same ammount it was tubbed, then you look at the height of the sills from the floor... on my front subframe ( a home made K series subframe ) i have 30mm ground clearance from the lower legs. I have bashed in on the floor on several occasions but you get used to it, but with it set up i feel it will out handle and out run pretty much anything within reason.
Edited by Broomer, 14 January 2012 - 09:27 AM.
#42 conlad
conlad
  • 2,054 posts
Posted 14 January 2012 - 09:31 AM
Ahhh too expensive for me then :( gutted, what advantage does it give apart from just being loads lower?
#43 Broomer
Broomer
  • 1,771 posts
Posted 14 January 2012 - 09:34 AM
It doesnt scrub,and if it does it will scrub on a flat sheet rather than the lip of the standard metal arch.
Prob one of the best modifications on my car.
#44 conlad
conlad
  • 2,054 posts
Posted 14 January 2012 - 09:38 AM
Hmmmm something to consider a lot later on I tink, cheers broom :)
#45 craig 1010cc
craig 1010cc
  • 1,165 posts
Posted 14 January 2012 - 10:01 AM
tubbing doesn't lower your car, just means that you can run it lower
One of my old workmates brother built a mini which he raised the rear subframe mounts and boot floor to get the a@se really low (also meant he could run the exhaust right up high in the tunnel as it didn't have to go under the rear subframe :) )
