Does Subwoofer Increase Fuel Costs That Much?
Samwise777
, Jan 12 2012 08:50 PM
8 replies to this topic
Posted 12 January 2012 - 08:50 PM
I recently bought a 12" subwoofer that will just about fit in my boot, it's brand new and will improve the audio in my car significantly
HOWEVER a couple of people have already warned me that it's gunna increase my fuel consumption a lot- I know it's more weight (think the sub weighs around 20kg) but will it be a noticeable difference? Cheers
Posted 12 January 2012 - 08:55 PM
If it does increase it will be hardly noticable.
Posted 12 January 2012 - 08:56 PM
I have always had subs etc in allmy cars i suppose it will decrease it a little but i really cant see myself any difference which is a good thing as my right foot does enough decreasing ;)
Posted 12 January 2012 - 08:57 PM
Ooops increase i mean
Posted 12 January 2012 - 08:59 PM
any weight in a mini makes a difference, you will feel it, i planned to put a sub in, but my 6X9's were good enough for bass, makes my seats vibrate
also, it gives me more space in the boot without it for the more important stuff, i took my spare out as i dont go far enough and theres always someone who can bring me it if i need but, but i got the foam spray stuff just incase, but you've got to drive to accomidate it, so just drive it smooth and use your gears to slow you down in stead of harsh breaking. Also be aware that as the alternators arent that powerful in a mini, when you have everything on in, including lights, heater, heated window it may not even be charging your battery and your drawing to much current so it use the battery energy too, so i you play your music without the engine running, it'll drain your battery, therefore meaning you'll end up having to run it just to charge you battery, so if you do go for it, sometimes during the day when driving leave your radio off to give your battery a good charge, i learnt this the hard way, especially when its cold, makes the battery worse :/ but good luck with it :) if its done right it'll be good.
Posted 12 January 2012 - 09:03 PM
I'm over 100kg!
I'd effect your fuel economy more!
Posted 12 January 2012 - 09:09 PM
cant see that 20 k will would notice hardly any difference in performance
may be bit more in a 998 but 1275 no
and certainly not enough to worry about fuel particulary in a 1275
Posted 12 January 2012 - 09:11 PM
well yeah, after being a little more observent, in a 1275 yeah, im sure you'll be fine :L just any bit of weight i can feel
Posted 12 January 2012 - 09:24 PM
Yeah it's a 1275 I've got so hopefully I should be in the clear then :) this is just what i wanted to hear so cheers for the comments! Just gotta fit the bloody thing now!!
