My Mini Project
1238 replies to this topic
#406 Andrew O
Andrew O
    Previously known as Andrewo330.
  • 1,425 posts
Posted 14 July 2012 - 04:01 PM
Why don't you do a separate thread for the Picadly ?
Andrew
#407 ToM 2012
ToM 2012
  • 4,066 posts
Posted 14 July 2012 - 04:13 PM
hi andrew it isnt a full rebuild so just posting up pictures of it near enuff finished now.
#408 markje
markje
  • 183 posts
Posted 14 July 2012 - 04:47 PM
So the electrical problem solved or do you have still some minor problems?
#409 ToM 2012
ToM 2012
  • 4,066 posts
Posted 14 July 2012 - 04:54 PM
everything works except for the hazard lights i checked the relay and thats fine as i tryed it on the other mini so have not got a clue now.
#410 markje
markje
  • 183 posts
Posted 14 July 2012 - 04:57 PM
right.. do you have a multimeter so you can see if you measure some volts,it not then you can look if you switch is ok,I had a polluted switch cleaned it and it worked
#411 ToM 2012
ToM 2012
  • 4,066 posts
Posted 14 July 2012 - 05:08 PM
hi i don't have one but i can get one of a friend and i have tried the switch in the other mini to and that works so cant be the switch
#412 markje
markje
  • 183 posts
Posted 14 July 2012 - 08:41 PM
test the fuse,and use a multimeter if wel make life easier to find electrical mailfuctions
#413 ToM 2012
ToM 2012
  • 4,066 posts
Posted 14 July 2012 - 08:50 PM
ok mate cheers will let you no how i get on
#414 minimuk
minimuk
  • 1,946 posts
Posted 14 July 2012 - 09:54 PM
me thinks it is the wire from the switch to relay. have you tried another hazard switch ?
#415 ToM 2012
ToM 2012
  • 4,066 posts
Posted 15 July 2012 - 10:05 AM
yes tryed new switch new relay fuses are ok so must be the wiring thats perished can i join a wire onto a live and hook it straight up to the relay positive? thanks tom
#416 minimuk
minimuk
  • 1,946 posts
Posted 15 July 2012 - 10:39 AM
have you checked there is live going into the hazard switch, use multimeter to check this. is the lve wire to hazard switch connected to the second fuse? if live all good,....check there is live going to relay,.....at the switch first then the relay side,....
conclusion start from here..........
live wire to switch correct fuse (second fuse from the top)
live going into switch (check at fuse box first then +inlet on switch)
live coming out of switch
live going into relay live coming out of relay(going to indicator lights)
Ok wiv that?
#417 ToM 2012
ToM 2012
  • 4,066 posts
Posted 15 July 2012 - 10:46 AM
Ok wiv that?
will try this today and will let you no how i get on. cheers:)
#418 TURBO-TOM
TURBO-TOM
  • 50 posts
Posted 15 July 2012 - 06:44 PM
your project is awesome mate, keep up the good work. its going to be a very nice mini when its done.
#419 ToM 2012
ToM 2012
  • 4,066 posts
Posted 15 July 2012 - 06:48 PM
thanks very much =]
#420 STREET TWEAKS
STREET TWEAKS
  • 662 posts
Posted 16 July 2012 - 08:52 PM
got sum more work done to the wing 2nite and got the lines looking alot better , will put pics up soon
