can not wait mate should look a lot beta then
happy days then,...good luck to you both,....any luck Evy won't be long after.........I wish....
Edited by minimuk, 27 March 2012 - 09:53 PM.
Posted 27 March 2012 - 09:53 PM
Posted 28 March 2012 - 06:38 AM
Posted 01 April 2012 - 03:45 PM
Posted 01 April 2012 - 05:20 PM
Posted 01 April 2012 - 05:35 PM
Posted 01 April 2012 - 06:43 PM
Posted 01 April 2012 - 07:18 PM
welcome to the mini forum we all will be happy to help to any of your problems also thankyou for the nice comment cheers tomHi, Just joined this website because hopefully i`ll be purchasing my first mini soon and doing a full restore back to originallity (as i can get it)
. Just looked through your thread and gotta say it`s a top job so far and hopefully i can do as good a job, keep up the good work mate
Posted 01 April 2012 - 07:21 PM
hi graham there is a few shims but that gap down passenger a panel is quiet bad but if i take the shims out to bring it closer to the a panel the top off the door will hit so i was thinking of adding metal on down the a panel to loose the gap any ideas? drivers side i can live with cheers tomNot too bad on the fit, any shimming going on ?? Have a look at the door gap section pinned in the bodywork section. Not too far off though, mine went from like yours to crap fit today !!!
Graham
Posted 01 April 2012 - 07:24 PM
hi mate i havent got a welder i will mention it to street tweeks as he will be fitting new door skins so he might be able to do something to make it better cheers tomDriver side looks fine, Nearside,...... I would weld a seam on the door edge, (christ sake not on A-panel edge) thin on top, wider in middle and thin on bottum, grind back a sand flat, use copper piece to absorb heat and weld on low amps, (setting 1 and min) pending what welder you have,in 1 inch sections up and down so nout get to hot, have a nice 3-4mm gap top to bottum and around the whole door-frame, you might have to do this a few times to get it right, but worth while doing.
Posted 01 April 2012 - 07:35 PM
Posted 01 April 2012 - 07:58 PM
Posted 01 April 2012 - 08:12 PM
hi thanks i have not tryed this i will measure next time cheers tomyou might find that the dos skin has been altered before you got the door so a new door skin might even be what you need. have you tried measureing the gapes for the door to see if one side is bigger / smaller?
cheershi thanks i have not tryed this i will measure next time cheers tom
Posted 02 April 2012 - 07:46 PM
Posted 02 April 2012 - 08:17 PM
