Some Advice With The Heel Board Corner Repair Please?
20 replies to this topic
#16 087dave
087dave
  • 952 posts
Posted 20 July 2013 - 08:32 AM
It is wrong, but unlikely to be UNC, far more likely to be M8. Under no circumstances try to retap it, as that will leave it hopelessly weak. You could try M8 bolts but make sure that they are marked 8.8, not an inferior grade.
Get stainless steel M8, 8.8 or only galvanised bolts
#17 jmac201
jmac201
  • 229 posts
  • Local Club: CCKT
Posted 20 July 2013 - 09:08 AM
So just made it back from the store, turns out they are in fact the M8 threads, now just gotta order some hardened bolts instead of the cheapo's they had in stock.
I wish they would have advertised when you buy the panel it may not have the right threaded nut installed
Edited by jmac201, 20 July 2013 - 09:09 AM.
#18 jmac201
jmac201
  • 229 posts
  • Local Club: CCKT
Posted 20 July 2013 - 09:10 AM
I think you are talking about mine, From post #82
http://www.theminifo...-rebuild/page-6
Thanks!  That's the one I was thinking of.  Did everything work out alright, still holding good?
Thats alright, I still haven't had the subframe back on, but I'm sure it'll be fine.
I may just go with new bolts, I don't want to buy a set of taps just to do this.  I do like the idea of just one block with threads in it.
#19 tiger99
tiger99
  • 8,584 posts
Posted 20 July 2013 - 10:52 AM
078dave, please do not give dangerous advice. The issue of stainless bolts has come up here many times, and they are known not to be safe, except in places which are purely cosmetic.
#20 087dave
087dave
  • 952 posts
Posted 20 July 2013 - 12:39 PM
I am not given dangerous advise, what happens when the galvanised material rusts off and the salt from the roads attacks it
#21 jmac201
jmac201
  • 229 posts
  • Local Club: CCKT
Posted 20 July 2013 - 05:58 PM
2nd Tiger 99,  Stainless Steel bolts for load bearing/high stress not a good combo.  I'm going to replace most bolts/nut in high rust/stress areas with Chromoly from ARP, expensive but good quality
