The Rat
2942 replies to this topic
#391 camp freddy
camp freddy
  • 3,696 posts
Posted 13 September 2007 - 10:18 PM
Not bad there sir! They a complete set? and do you have the correct "numbers"?
numbered 1 up to 8, spent about 15 mins looking at them, for £20 took the chance
cleaned the paint off when i got home and they are ok
#392 camp freddy
camp freddy
  • 3,696 posts
Posted 13 September 2007 - 10:20 PM
Do u like my hinges :turtle:
flash bugger, i havn't got all your money to spend :) :-
#393 Dog
Dog
    Deathwish Fairy
  • 9,550 posts
  • Local Club: Shatrats.com
Posted 13 September 2007 - 10:21 PM
Awesome - all I can say, is take your time with it. Doing the A-Panels etc, is easy, but its when it gets to the doors, when its the PITA... If the A-Panels aren't quite right, the hinges don't work, or if the A-Panels are straight and you've not tightened the hinges up right... the door just won't open. I can't stress enough how much you need to take ur time lol
The hinges are still in the garage... But they'll be going on Flubber over the winter, when I can afford some new doors for him :turtle: No more having the lift & slam my doors again then :-
Edited by Ðogmatix, 13 September 2007 - 10:22 PM.
#394 camp freddy
camp freddy
  • 3,696 posts
Posted 13 September 2007 - 10:30 PM
going to fit the doors and wedge in with wedges all round, then fit the a panel to line up with the door and tack in position
through drilled holes onto the hinge panel. take off door and finish a panel. re-fit door and wedge, offer up the hinges
to find position where the hinge arms are parallel when open and mark this position, make a template for the holes
offer this up then drill through, then i've got to make a stiffener plate for the inside of the a panel..
how does that sound ??
how much did you pay for your hinges ?
#395 camp freddy
camp freddy
  • 3,696 posts
Posted 23 September 2007 - 09:36 PM
Hello there. Done a bit more this afternoon, been a bit lazy lately so I thought
I'd better get my arse into gear today.
boxed in the gap between the inner sill and the rear quarter panel, where
the rear bins should be, not having any bins.
the gap
blanked off
primed up
also started on my fiberglass front, used the original bonnet hinges as I this
these are suitable for the job,
cut half the stiffener frame from the old bonnet
placed the front on the car and lined up, marked the the frame position under the front
then removed and fiberglassed in place
pictures showing front in position
up
down
just had to tweak the flanges on the scuttles to allow the top rear of the
wing to pass.
Not bad , and no need for a fancy hinge setup :genius:
Edited by camp freddy, 27 August 2008 - 08:16 PM.
#396 Retro_10s
Retro_10s
    Moderator
  • 10,138 posts
Posted 23 September 2007 - 09:40 PM
:genius:
flange
:thumbsup:
s'gonna be a damned fine car this :P
Edited by Retro_10s, 23 September 2007 - 09:40 PM.
#397 camp freddy
camp freddy
  • 3,696 posts
Posted 23 September 2007 - 09:43 PM
now't like tweaking the Flanges !!!!!!!!!!!!!!! :genius:
#398 mineeeeee
mineeeeee
  • 117 posts
  • Local Club: me and my mini
Posted 24 September 2007 - 01:05 AM
Just read all this post
I would have cryed for a month if i found that lot
Give this man a cigar
#399 stanley and naomi
stanley and naomi
  • 504 posts
  • Local Club: Southwest Cornwall
Posted 24 September 2007 - 01:34 PM
loovely mini - it will be worth the hard work in the end - love the flames down the side :genius:
#400 JetBLICK
JetBLICK
  • 1,222 posts
  • Local Club: myspace.com/worcesterretro
Posted 24 September 2007 - 04:46 PM
Thats an ingeniously simple way of doin the reverse flip front..... how come no-ones done that before! Do you not have any problems clearing the wheels or anythin else - i automatically assumed thats why it hadnt been done before. Well done!
#401 camp freddy
camp freddy
  • 3,696 posts
Posted 24 September 2007 - 09:09 PM
Thanks for the comments,
Jetbick, the wheels are on with no problems, the only problem was the outer
part of the scuttle, this needed to be reshaped so the lower part didn't flare out,
as it stopped the top part of the wing passing, a bit hard to explain but if you've removed
a wing you'd know the bit i'm on about.
I decided to utilise my original hinge points as i couldn't see why you would need
alternative hinging as there is no real weight to carry, plus the front part of the bonnet
was rotten so it was scrap anyway, so no loss if it didn't work out.
Stanley and Neomi, sorry to say the flames have gone !! even though my lad wanted
me to keep them, bless him :dontgetit:
Mineeee, I don't smoke :wub: Only when welding if i'm not carefull.
Edited by camp freddy, 24 September 2007 - 09:20 PM.
#402 Retro_10s
Retro_10s
    Moderator
  • 10,138 posts
Posted 24 September 2007 - 09:17 PM
I was considering using mini boot hinges for the front on my old clubby,... but i must say,.. using those other hinges will look nice!.. a lot sleeker.
#403 camp freddy
camp freddy
  • 3,696 posts
Posted 26 September 2007 - 09:10 PM
Went out tonight and sorted out the gas strut for
the front end, the way it is mounted it holds
the front open and when lowered it pulls the
front shut, best of both worlds. it is a 150 NM
strut which we use at work on the luggage lockers.
Handy working for a carriage builders :gimme:
UP
Down
Edited by camp freddy, 27 August 2008 - 08:21 PM.
#404 miniboo
miniboo
    Lord of Original Thinking
  • 9,327 posts
Posted 27 September 2007 - 12:53 AM
WOW!!
#405 TimS
TimS
    Mini Doctor
  • 2,712 posts
Posted 27 September 2007 - 05:19 PM
That’s really a really good idea putting those bonnet strengtheners on. :thumbsup:
