Very clever, there's probably a market for that ££££
The Rat
#2926
Posted 23 May 2014 - 05:52 AM
#2927
Posted 28 May 2014 - 04:53 PM
#2928
Posted 28 June 2014 - 09:27 PM
Well not been on here for a while but i'll update what i've been doing..
Decided to mod the Turbo head I got with the turbo set up , then sent it to have the valves
and seat triple angle cut
chamber
ports
stripped the engine , new rings , shells etc ,fitted an MG metro cam , duplex chain , central oil pick up
painted it green
painted the head and fitted it
#2931
Posted 28 June 2014 - 09:57 PM
The turbo has an oil feed to it but it needs to return back into the engine, the blanking plate
over the mechanical pump hole is used for the oil return, had a search and couldn't find
an adapter so I made my own
the blanking plate I had previously made, pic also show the return outlet from the
turbo
cut a piece of pipe and drilled a hole in the blanking plate
welded the pipe cut down then welded a thin bit of larger pipe to the end
dressed off and rounded the end
fitted in position ready for the connecting hose
#2932
Posted 28 June 2014 - 10:03 PM
Decide to fit a breather to the rocker cover..
made a bend out of some small pipe drilled the cover and welded in the pipe
made a baffle plate and welded it inside the cover to prevent oil from being blown
directly out the breather
with breather fitted, the pipe is fitted between the set of rockers
#2933
Posted 28 June 2014 - 10:10 PM
Had to replace the fuel line as the turbo set up needs a high pressure dual line with
a bigger bore. so replaced the 8mm with 10mm copper micro bore that I had
been using for an external air line extension...
had to run the either side of the seat bulkhead due to the pump feed in the boot, ran
the pipes inside the car as before , secured with stainless 'p' clips
rear
front
#2934
Posted 25 November 2014 - 02:35 PM
THE END?
#2935
Posted 21 January 2015 - 10:51 PM
due to various issues I have had 3 engine changes and have had to haverify the turbo reconditioned. ...
all's good now though
#2936
Posted 03 June 2015 - 05:55 PM
You overtook me on the A46 think it was. I was in a old skool cream Hyundai pick up
#2937
Posted 03 June 2015 - 05:57 PM
#2938
Posted 03 June 2015 - 06:57 PM
#2939
Posted 22 August 2015 - 11:35 AM
#2940
Posted 22 August 2015 - 11:40 AM
