The Rat
2942 replies to this topic
#2911 camp freddy
camp freddy
  • 3,696 posts
Posted 07 February 2014 - 08:22 PM
Also made a template for front speaker pods, took 2hrs in all , fitting under the shelf on the inner wing
made the pods at work , welded and dressed
rattle can green
fitted and bought some FLI speakers to replace the ones I had fitted at first
#2912 jt19
jt19
  • 745 posts
Posted 07 February 2014 - 11:33 PM
this is a long project!! you must be so pleased with it! It's come a long way from when you got it!!
#2913 camp freddy
camp freddy
  • 3,696 posts
Posted 08 February 2014 - 02:25 PM
Yeh.. cheers Jt always changing things . Adding new bits. That's where the enjoyment is
#2914 camp freddy
camp freddy
  • 3,696 posts
Posted 11 February 2014 - 06:21 AM
welded the intake pipe onto the plenum
received the new cone filter
#2915 camp freddy
camp freddy
  • 3,696 posts
Posted 27 February 2014 - 10:38 PM
getting the tune up bits ready for the engine upgrade,,
central oil pickup
Kent 286 road/race cam
Duplex chain
#2916 camp freddy
camp freddy
  • 3,696 posts
Posted 02 March 2014 - 08:14 PM
Not much done with regards to the engine upgrade, trying to source a big valve / ported head at present,
Like a fool seen one on ebay dithered about and lost it £70 BIN , what a plonker.....
#2917 camp freddy
camp freddy
  • 3,696 posts
Posted 23 March 2014 - 09:22 AM
well . bought an MG metro head ( big valve ) decided to port it and mod the combustion chambers... heres
some pics
#2918 Brams96
Brams96
  • 2,308 posts
Posted 23 March 2014 - 07:13 PM
Looking good, that'll give you some better breathing to the engine. Are you going to polish the combustion chamber around the valves?
#2919 camp freddy
camp freddy
  • 3,696 posts
Posted 23 March 2014 - 11:06 PM
May do a bit . But according to the Vizard book polishing gives no real advantage. .
#2920 camp freddy
camp freddy
  • 3,696 posts
Posted 05 April 2014 - 02:56 PM
Well what do I say....... may be going in a different direction... been given a turbo head and complete turbo set up. ...... now what to do....
#2921 yeti21586
yeti21586
    He's A Lumberjack And He's OK
  • 3,724 posts
  • Name: Chris
  • Local Club: None
Posted 05 April 2014 - 04:46 PM
Give it to me????
#2922 camp freddy
camp freddy
  • 3,696 posts
Posted 06 April 2014 - 08:15 AM
All the parts I've got for twin su's won't be needed if i go turbo....... could use the head but may as well mod the turbo one...
Edited by camp freddy, 17 April 2014 - 08:41 PM.
#2923 camp freddy
camp freddy
  • 3,696 posts
Posted 17 April 2014 - 08:54 PM
well started.. took out the weber box and heater , also stripped out the dash
Then cut out the bulkhead for the turbo box, bigger than usual due to having the weber box
made the turbo box at work
positioned in place and trimmed to suit
view from inside
welded in position, just have a small gap at the top will need to put a piece inside to weld body and
box too
That's where i'm up too body mod wise.....
#2924 camp freddy
camp freddy
  • 3,696 posts
Posted 22 May 2014 - 09:24 PM
Turbo bulkhead finished
piston ring grooves cleaned out and new rings fitted
4.05 kg flywheel fitted
Edited by camp freddy, 22 May 2014 - 09:25 PM.
#2925 camp freddy
camp freddy
  • 3,696 posts
Posted 22 May 2014 - 09:28 PM
Made a device to lock the flywheel
locates on the two starter motor mount holes
tab locates on the flywheel teeth
