The Rat
2942 replies to this topic
#2866 camp freddy
camp freddy
  • 3,696 posts
Posted 13 August 2013 - 10:01 PM
Ratty having all his boots swapped today
#2867 camp freddy
camp freddy
  • 3,696 posts
Posted 14 August 2013 - 08:05 PM
Dressed the manifold this afternoon, looks a tad better :D
#2868 camp freddy
camp freddy
  • 3,696 posts
Posted 18 August 2013 - 07:09 AM
went out the other day and after giving the garage a much needed tidy up decided to have a look at the carbs,
Had to cut down the linkage bars as the 1 1/2 HIF's are wider than 1 1/4's so need a shorter bar, the choke
mechanism only needs the bar and the two forked prongs as the cable attaches to the swivel locator plate
The throttle bar also needed cutting , but due to the gap between the locators being narrower I had to
cut down the forked prongs to enable me to fit the actuator arm, I now need to locate the forks and arm
in the correct position then weld them together..
Next thing to do will be to make a cable support bracket to mount onto the manifold and then sort out
the cable clamping.....
As you can see on this picture I have used carb spacers with built in vacumm take offs, I have
used these to allow for easy balancing the airflow.....
And that's where I am for now....
Edited by camp freddy, 18 August 2013 - 07:18 AM.
#2869 camp freddy
camp freddy
  • 3,696 posts
Posted 27 August 2013 - 09:18 PM
Did a little job at work, had to alter the throttle arm, needed to extend it by welding
on an extension piece.
#2870 camp freddy
camp freddy
  • 3,696 posts
Posted 16 September 2013 - 08:26 PM
Oooooopps slght incident near Stanford hall, Stone kicked up by another
club members tyre
got some bits for the new engine
Lightened flywheel
non-bypass water pump
head gasket
#2871 rally515
rally515
  • 3,848 posts
Posted 16 September 2013 - 08:34 PM
Uprade to a Laminated screen now perhaps ? ;) how big was the stone haha
#2872 Tupers
Tupers
  • 4,176 posts
Posted 16 September 2013 - 08:39 PM
Ouch, I bet that was a bit scary. It doesn't take a big stone to shatter a toughened screen just a fast one.
#2873 camp freddy
camp freddy
  • 3,696 posts
Posted 16 September 2013 - 08:40 PM
Don't know the size , must have bounced off....... honestly thought it was a laminated screen , obviously
not LOL.......
#2874 camp freddy
camp freddy
  • 3,696 posts
Posted 16 September 2013 - 08:43 PM
We were doing about 60 down the roads near Stanford , only about half a mile away .....
almighty BANG!!!!! but stayed in place for a few minutes and gradually started breaking
up..
#2875 rally515
rally515
  • 3,848 posts
Posted 16 September 2013 - 08:44 PM
Haha lucky in a sense possibly, i remember i guy on here was going down the motorway and a bird flew infront of his mini and went threw the windscreen, hit his face (At 50mph!!!!!!!) and landed on his backseat :lol:
#2876 camp freddy
camp freddy
  • 3,696 posts
Posted 17 November 2013 - 08:46 PM
well had a lack of concentration while attempting to put my harness on while driving....
drove into the lane devider.. took the corner off my arch
Used apoxy resin to glue the broken bit on and a small steel rule and g clamps to hold in place
after it hardened sanded down to allow building up
then used glass fibre filler to build back the profile
I then used the sander to shape the glass fibre
Just to give it colour I then primed and sprayed it with some green paint I had....... Will leave it like this
for now until I alter the arches
Edited by camp freddy, 17 November 2013 - 08:48 PM.
#2877 rally515
rally515
  • 3,848 posts
Posted 17 November 2013 - 08:52 PM
Jeeze unlucky Freddy, this is the second time you,ve had to repair your arches now right? must be getting good at it now aye :lol:
#2878 camp freddy
camp freddy
  • 3,696 posts
Posted 17 November 2013 - 08:57 PM
Mm yes, all practice lol.....
Edited by camp freddy, 17 November 2013 - 10:24 PM.
#2879 camp freddy
camp freddy
  • 3,696 posts
Posted 17 November 2013 - 08:59 PM
Will be taking them off at some point to fit them higher so I can lower the front, as when I fitted them
I put them on too low....
#2880 steven
steven
  • 1,195 posts
Posted 17 November 2013 - 09:05 PM
Nice repair
