The Rat
2942 replies to this topic
#2551 camp freddy
camp freddy
  • 3,696 posts
Posted 05 October 2011 - 05:20 AM
OOOOOPPPPPSSSSS , think I found the problem !!!!! removed the bigend cap and found the
shell coating had been worn through . also noticed that the key had been partly flattened . so
the shell must have mooved round when I fitted it.
new shell set been ordered and gaskets ...... oh well....
Edited by camp freddy, 05 October 2011 - 05:21 AM.
#2552 camp freddy
camp freddy
  • 3,696 posts
Posted 08 October 2011 - 11:33 AM
Waiting for the shells to arrive ,have stripped and cleaned the head , also lapped in the valves . Modded the oil pick up pipe and refitted it.Have also pre-lined the crank and refitted that.
Edited by camp freddy, 08 October 2011 - 11:38 AM.
#2553 Artful Dodger
Artful Dodger
    " I AM THE SPECIAL ONE"
  • 4,435 posts
Posted 08 October 2011 - 02:01 PM
wow, that were lucky!
are you not going to give the crank a going over or is it ok?
#2554 camp freddy
camp freddy
  • 3,696 posts
Posted 08 October 2011 - 03:09 PM
crank looks fine , had a good look over it .
decoked the head and re-seated the valves yesterday , was pretty cacked
up from before I re-ringed, I didn't clean it before I rebilt the block last time >_< .....
looks better now
Also modded the oil feed pipe , checked and re-lubed the crank mains ready for the re-build
#2555 camp freddy
camp freddy
  • 3,696 posts
Posted 10 October 2011 - 09:58 PM
re- assembled the head and found that I also have a bent push rod .... oh well....
#2556 camp freddy
camp freddy
  • 3,696 posts
Posted 16 October 2011 - 09:39 PM
got to buy a new piston to go on the replacement rod ..... another £45 :ohno:
#2557 camp freddy
camp freddy
  • 3,696 posts
Posted 20 October 2011 - 04:21 PM
just got a full set of rods and pistons the type I need off Fleebay for £57 , :D ..... re-build will
soon commence...
#2558 camp freddy
camp freddy
  • 3,696 posts
Posted 26 October 2011 - 07:18 PM
still waiting for the replacement rods and pistons to arrive , hope they turn up tomorrow ....
#2559 liirge
liirge
  • 4,097 posts
  • Local Club: EDMC AND MMC
Posted 26 October 2011 - 07:21 PM
So do I!!!! Always like following this.
#2560 camp freddy
camp freddy
  • 3,696 posts
Posted 26 October 2011 - 07:40 PM
the only problem now is that James1275sprite's build is pushing me towards turboing Ratty...... :shifty:
I've been scouring Ebay , but James may have a spare one....
#2561 CaptainBland08
CaptainBland08
  • 675 posts
Posted 27 October 2011 - 05:18 PM
cut bulkhead or special manifold?
#2562 camp freddy
camp freddy
  • 3,696 posts
Posted 29 October 2011 - 09:57 AM
Finally got the new rods and pistons, had to collect them from
the Citylink depot in the end, they look in very good condition
i might change them all !
will be out later resuming the build..
#2563 camp freddy
camp freddy
  • 3,696 posts
Posted 29 October 2011 - 12:11 PM
if i did i would modify the bulkhead and the rear part of the subframe to allow an lcb to be modded
to fit a turbo... :D
#2564 camp freddy
camp freddy
  • 3,696 posts
Posted 30 October 2011 - 08:24 AM
partly built engine ,should be done by this evening :proud:
Edited by camp freddy, 30 October 2011 - 08:26 AM.
#2565 camp freddy
camp freddy
  • 3,696 posts
Posted 30 October 2011 - 06:43 PM
Damn......... went to fit the clutch housing didn't realise the motion shaft support
bearings were different sizes , damaged the plastic bearing race so I have to get
a new one... oh well a least it's one less part to fail......
