The Rat
2942 replies to this topic
#2521 analogue_radio
analogue_radio
  • 4,897 posts
Posted 14 August 2011 - 10:22 PM
Well done on the magazine feature!
#2522 1275 SPRITE
1275 SPRITE
  • 1,188 posts
Posted 15 August 2011 - 10:33 AM
What happened with the engine? I didn't see you at mitp??
#2523 camp freddy
camp freddy
  • 3,696 posts
Posted 15 August 2011 - 09:51 PM
Not running, can't decide whether to tow start or strip it AGAIN just to make sure every things ok.
DId you get to MITP in yours.......
#2524 CaptainBland08
CaptainBland08
  • 675 posts
Posted 15 August 2011 - 10:05 PM
how tight are we talking??? does a socket and ratchet turn it over if you stick it on the end of the crank?
#2525 camp freddy
camp freddy
  • 3,696 posts
Posted 15 August 2011 - 10:10 PM
just ! on the bench, I have never had this problem before...
Edited by camp freddy, 15 August 2011 - 10:26 PM.
#2526 1275 SPRITE
1275 SPRITE
  • 1,188 posts
Posted 16 August 2011 - 01:13 PM
No, didn't quite make it. Could probably have made it if we worked late on sat night, but wouldn't have been able to Mot it. Should easily have it mot'd this week. Ideally you should have turned it over after fitting bits at different stages, would have picked the problem up sooner.
#2527 camp freddy
camp freddy
  • 3,696 posts
Posted 16 August 2011 - 10:32 PM
i didn't just throw it alltogether LOL..... I did check it , did turn over in all stages on the bench, admit that it needed a torque wrench to turn it ,but it did turn, if you put it in gear and turn the key it will move the wheels , so I am happy that the engine is not jamming on the gearbox, also if you depress the clutch the car will roll while in gear so I know the gearbox is free.
#2528 1984mini25
1984mini25
  • 8,784 posts
Posted 16 August 2011 - 10:41 PM
I had a problem with one of mine I rebuilt recently were it would turn over freely by had while be assembled, but if left for any length of time it would seize up or be very tight to turn over. Turned out after pulling it apart that one of the bearing shells was not quite seating correctly.
#2529 camp freddy
camp freddy
  • 3,696 posts
Posted 20 August 2011 - 07:36 PM
NEWS FLASH !!!!!!!
Ratty is now running.........after a plugless tow and mess around with
plug leads...........
Stanford hall here we come.......
#2530 camp freddy
camp freddy
  • 3,696 posts
Posted 20 August 2011 - 10:49 PM
first run out , got stuck behind an old codger doing 20mph on the twyford road to Queniborough, running in
so had to be a little reserved when overtaking....
Edited by camp freddy, 21 August 2011 - 10:19 AM.
#2531 camp freddy
camp freddy
  • 3,696 posts
Posted 21 August 2011 - 08:15 AM
another vid, a bit of popping...
#2532 bcjames
bcjames
  • 2,728 posts
Posted 21 August 2011 - 10:01 AM
Ratty is awesome, good to see him back on the road!! I've not seen him in person yet, but that'll hopefully change at Stanford!
#2533 camp freddy
camp freddy
  • 3,696 posts
Posted 21 August 2011 - 10:21 AM
4 months off the road is too long........
#2534 camp freddy
camp freddy
  • 3,696 posts
Posted 22 August 2011 - 08:09 PM
thought it was about time I sorted out Ratty's steering column bracket..... so I made one
today
Edited by camp freddy, 22 August 2011 - 08:11 PM.
#2535 camp freddy
camp freddy
  • 3,696 posts
Posted 23 August 2011 - 03:34 PM
Ratty is now Mot'd again thanks to James, Nice to have a mini friendly
Mot station local.....
