The Rat
2942 replies to this topic
#2476 camp freddy
camp freddy
  • 3,696 posts
Posted 12 June 2011 - 12:24 PM
That cranks proper had it, skip job I reckon. Like you say the casting looks like poo!
reckon it was fitted like that from new !!!!!!!! , found a 6581 Turbo crank that i'm hoping to
get :) , just need to know whether it will fit an 'A' series block, both have 1.75'' journals.
#2477 camp freddy
camp freddy
  • 3,696 posts
Posted 13 June 2011 - 07:44 PM
good 1275 crank wanted, turbo preferred.......
#2478 camp freddy
camp freddy
  • 3,696 posts
Posted 18 June 2011 - 06:46 PM
went to Minispeed today, took with me 3 cranks (2 rusty) and a couple off old 12g940
heads (both with broken studs). swapped them for a re-con nitrided crank, :proud: also had
a set of main and big end shells, shims and a full set of rings. should have been
£135 but got 20% off so only paid £100.... so a good day
Edited by camp freddy, 18 June 2011 - 06:57 PM.
#2479 CaptainBland08
CaptainBland08
  • 675 posts
Posted 19 June 2011 - 04:49 PM
heads (both with broken studs). swapped them for a re-con nitrided crank, :errr: also had
nitrided crank out of an early metro turbo???
should be a strong old bugger once rebuilt...
#2480 camp freddy
camp freddy
  • 3,696 posts
Posted 20 June 2011 - 09:53 PM
heads (both with broken studs). swapped them for a re-con nitrided crank, :) also had
unfortunately not, it's the 6323 crank std 1275 filleted crank.
been out tonight and polished the journals up.Posted Image
need to get some cam bearings now..
#2481 camp freddy
camp freddy
  • 3,696 posts
Posted 26 June 2011 - 10:09 PM
not received my parts from Minispares which I hoped to get before this
weekend, :) So decided to refresh Ratty's front wheel arches and clean
up the engine bay.
front wheel arch
engine bay
#2482 GTIAlex06
GTIAlex06
  • 1,562 posts
Posted 26 June 2011 - 10:14 PM
what did you use on ur front arches?
#2483 camp freddy
camp freddy
  • 3,696 posts
Posted 26 June 2011 - 10:46 PM
painted them then used Hammerite stone chip guard ,can be painted if needed.
#2484 1984mini25
1984mini25
  • 8,850 posts
Posted 26 June 2011 - 10:54 PM
The front arches and engine bay aren’t looking as ratty now. :)
#2485 camp freddy
camp freddy
  • 3,696 posts
Posted 26 June 2011 - 10:57 PM
The front arches and engine bay aren't looking as ratty now. :)
ha ha, hopefully his new motor won't dump oil over the bulkhead and help peel
the paint off..
#2486 camp freddy
camp freddy
  • 3,696 posts
Posted 02 July 2011 - 10:10 PM
made my own tool for pressing in the new cam bearings
also covered my door cards and rear cards with acoustic material
Also took my block in for some machining work on Friday, having the block
face skimmed and the bores lightly honed to de-glaze, for a cost of £50 bargain..
#2487 camp freddy
camp freddy
  • 3,696 posts
Posted 08 July 2011 - 08:13 PM
finally managed to get my block back today, went twice this week and the
machine shop was closed..... third time lucky .
Nice surprise though , only charged me £40 for a hone and block skim, was
quoted £50 when I dropped it off.. super bargain....
#2488 CaptainBland08
CaptainBland08
  • 675 posts
Posted 18 July 2011 - 09:47 AM
any more progress??? want to see this beasty running again!
#2489 izzy
izzy
  • 190 posts
Posted 18 July 2011 - 07:15 PM
i want to see some more pics cause its looking good.
#2490 camp freddy
camp freddy
  • 3,696 posts
Posted 22 July 2011 - 07:30 PM
Well I noticed that there were a couple of light score marks in the bores, I only
had it de-glazed so I decided to buy a honer and hone the bores . done it now
and ready for re-building. I've fitted the cam and the crank , just need to get
my pistons ring compressor back so I can drop the pistons in..
