The Rat
#2356
Posted 29 November 2010 - 09:55 PM
#2357
Posted 29 November 2010 - 09:57 PM
This is good to see. Aren't removable fronts a god send
yes ace, and poly quick release engine mounts
#2358
Posted 29 November 2010 - 10:02 PM
come out and was just hanging there LOL
#2359
Posted 29 November 2010 - 11:01 PM
Will it be attending the curry night?
Edited by charie t, 29 November 2010 - 11:01 PM.
#2360
Posted 29 November 2010 - 11:10 PM
You'll have a nice surprise in the morning, its snowing again
not sure yet, most probably.... if Ratty's done...
#2361
Posted 29 November 2010 - 11:21 PM
#2362
Posted 30 November 2010 - 08:19 PM
Good good, if i ever see my welder again mine might make itnot sure yet, most probably.... if Ratty's done...
#2363
Posted 30 November 2010 - 10:25 PM
at white wire to + coil, power at - coil terminal, power at w/blk wire to point fly lead but no power
at the points ? took the condenser out and replaced the fly lead then re-fitted, yippee spark at points.
still wouldn't fire, checked the rocker gaps when no8 was down no1 was still not rocking? had to loosen all
the rocker screws by at least a couple of turns, makes me think that the old block had shorter cam followers
in it. well alls fine know and he's running again.
how it goes.
#2364
Posted 22 December 2010 - 07:41 PM
LOL
#2365
Posted 22 December 2010 - 09:05 PM
hows it sticking to the sill when you have deseamed it?:S
Chris
#2366
Posted 22 December 2010 - 09:23 PM
lol:P
Chris
didn't stay there for long. just compacted I s'pose
#2367
Posted 22 December 2010 - 09:35 PM
Any ideas on what i might be doing wrong?
thanks
just fitted the bottom arms to Ratty, heres some pictures to ponder over
strengthening brace
fitted
toe adjusted and after being taken for a spin, slight caster adjustment next
#2368
Posted 22 December 2010 - 09:59 PM
Can i ask how to remove the arms for the subframe? I have undone the nut on the subframe which you can see in the third image below. but cant seem to get the bot out of subframe?
thanksjust fitted the bottom arms to Ratty, heres some pictures to ponder over
strengthening brace
fitted
undo the nut leave it on so it covers the thread, try tapping the pin out by hitting the
nut witha hammer, when the pin will not go any further use a pin punch or similar to
knock the pin free, you may have to work the arm off....
#2369
Posted 22 December 2010 - 10:11 PM
The bolt which attached the lower arm and the tie bar does it screw into
the tie bar as mine is stuck was going to try taping it out but didnt want to ruin the
tie bar if it had a thread going through it.
thanks
#2370
Posted 22 December 2010 - 10:13 PM
Thanks Very much i will give it a go tomorrow.
thanks
just a nut and bolt.... probably seazed
