The Rat
2942 replies to this topic
#1786 GraemeC
GraemeC
  • 7,435 posts
Posted 06 July 2009 - 09:15 AM
I have (or rather a pal has) some 13x6 Compomotives in an Alleycat style that might suit it:
#1787 1275 SPRITE
1275 SPRITE
  • 1,188 posts
Posted 06 July 2009 - 07:22 PM
Ive seen those compomotives before, they are really nice :thumbsup:
EDIT: Pic loaded up, they are different to the ones I was thinking of :P
Edited by 1275 SPRITE, 06 July 2009 - 07:24 PM.
#1788 1275 SPRITE
1275 SPRITE
  • 1,188 posts
Posted 06 July 2009 - 07:29 PM
These are the ones I was thinking of
CXR 1370 (compomotive)
#1789 camp freddy
camp freddy
  • 3,696 posts
Posted 06 July 2009 - 09:01 PM
they are xxxy , would be nice in satin black.....
#1790 leaky
leaky
  • 6,890 posts
Posted 06 July 2009 - 09:04 PM
Yea those wheels are nice. I still think you should keep the ones you had on their to begin with but paint them white.
#1791 camp freddy
camp freddy
  • 3,696 posts
Posted 06 July 2009 - 09:10 PM
Had a chat with my mrs's cousin tonight (who I had a load of bits off)
regarding the knocking shock. he said he had the same on his mini so he
replaced the shock, so the shock must be knacked, and its not bottoming out!
So a pair of shocks are now required..
Had half an hour on Ratty tonight so decided to wire the back lights
up on the water/oil gauges, heres a pick but you can't really tell
Edited by camp freddy, 06 July 2009 - 09:11 PM.
#1792 camp freddy
camp freddy
  • 3,696 posts
Posted 10 July 2009 - 09:43 PM
hopefully may get the new shocks tomorrow if posty delivers :P
Been out tonight for a run, had a go with a couple of chaps on the bendy bits
Ratty loves them!!!!. will be even better with the new shocks...
Edited by camp freddy, 10 July 2009 - 09:44 PM.
#1793 leaky
leaky
  • 6,890 posts
Posted 10 July 2009 - 09:57 PM
What are you going to do to the inteior. What dash and seat and waht not. Got any piccys.
#1794 camp freddy
camp freddy
  • 3,696 posts
Posted 14 July 2009 - 09:57 PM
Had a bit of a breakdown yesterday at work, when I got work
I noticed that I had water dripping from the engine bay :o
After closer examination I found that the dreaded bypass
hose was leaking coolent.
Left work a little earlier, topped up the coolant and headed off home.
due to the front end hinging from the scuttle it gives superb access to
the pump side of the engine,
so I stripped of the radiator, fan ,water pump and found the hose had dropped
( noticed when I fitted it it was a bit short :wub: but I fitted it any way)
bought some hose home from work but the bore was too small :D , decided to
re-fit the original hose but using Jubilee clips from work...
I also modded the speedo sensor so it was a more precise fit, pic
( notice I have utilised the original cable fixing nut)
While I was working on Ratty I also fitted the new G-Max gas shockers to the rear
and sorted out an issue with the rear brk lights.
Well took Ratty out for a spin, no knocking from the rear end Yipee!!
corners ace, even better !!! BUT!! when I got home noticed the bypass
was still leaking GGGGRRRRRR!!!. I have now ordered a Kevlar re-inforced
hose off fleebay, should get it tomorrow...
Mean while Ratty is home bound ;) And the Corsa is on the road again....
Edited by camp freddy, 14 July 2009 - 09:59 PM.
#1795 1275 SPRITE
1275 SPRITE
  • 1,188 posts
Posted 14 July 2009 - 10:05 PM
Seems like a perfect time to fit a stage 4 head without the bypass hose and block off the w/pump... not like I have one lying around or anything..... :D :wub:
#1796 camp freddy
camp freddy
  • 3,696 posts
Posted 14 July 2009 - 10:08 PM
MMMMMmmmmmmm!
#1797 1275 SPRITE
1275 SPRITE
  • 1,188 posts
Posted 14 July 2009 - 10:10 PM
MMMMMmmmmmmm!
:D
Oh, dont forget you dropped your socket on the floor :wub:
#1798 Saxo-Fiesta-Mini
Saxo-Fiesta-Mini
  • 2,889 posts
  • Local Club: LCMOC
Posted 14 July 2009 - 10:13 PM
A+ are awesome cause they dont have that issue :wub:
#1799 camp freddy
camp freddy
  • 3,696 posts
Posted 14 July 2009 - 10:16 PM
got an A+ in the garage !
#1800 Saxo-Fiesta-Mini
Saxo-Fiesta-Mini
  • 2,889 posts
  • Local Club: LCMOC
Posted 15 July 2009 - 09:49 AM
id be tempted if u ever go for a mental head get an aplus one and then u can block off the water pump and no problems
