The Rat
2942 replies to this topic
#1681 camp freddy
camp freddy
  • 3,696 posts
Posted 25 June 2009 - 05:13 AM
well i'm a bit p****d off tonight, got my parcel from Minispares
today, the door bolts i received are UCF not UNC thread, so no
good, the boot rubber clips that cost £8 !!!! ,well i just couldn't
figure out how they fitted to the rubber??? so i ended up just glueing
the rubber to the body... which actually is a better fit :D
Managed to fit the door trim clips :)
Would that be the old type seal which mounts to the boot lid?
I just took mine of to replace it.
Basicly there is a small lip on the body side of the rubber which the widest bit of the clip sits into, and then the folded edge is pushed fold first into the holes on the boot lid arround the edge, then it stays (in theory).
Dash is looking great now!
Chris
yes, thats what your supposed to do in theory,,, but in practise it doesnt work too well
,so i've glued mine..
#1682 Burnard
Burnard
  • 3,350 posts
Posted 25 June 2009 - 10:33 AM
lol, so long as it doesnt leak it wont be a problem untill you need to take it off.
c'mon man, ur getting impatiant in the last stages of this amazing build!
#1683 camp freddy
camp freddy
  • 3,696 posts
Posted 25 June 2009 - 08:03 PM
:thumbsup:
Edited by camp freddy, 25 June 2009 - 08:13 PM.
#1684 camp freddy
camp freddy
  • 3,696 posts
impatient!!! I spent 20 mins trying to get 1 clip to hold the rubber!!!! then
I thought s*d it !!!! :thumbsup:
Edited by camp freddy, 25 June 2009 - 08:12 PM.
#1685 camp freddy
camp freddy
  • 3,696 posts
Posted 25 June 2009 - 08:12 PM
tonight I fitted the window fillet to the window rubbers, I also set
all the door lock positions so the doors shut flush with the body.
fitted the interior handles etc, also fitted the window washer jet.
Jobs to do
washer bottle and pump *
washer switch *
wiper switch *
tacho pickup
water temp pickup
speedo cable adapter
strenghthen boot lock
that's about it.
jobs with * are needed for mot
#1686 Burnard
Burnard
  • 3,350 posts
pah, spent 2 hours fitting mine :thumbsup: well trying to get the boot to close after i fitted it.
You know im only joking :D
#1687 camp freddy
camp freddy
  • 3,696 posts
Posted 25 June 2009 - 08:16 PM
I first stuck mine where it should be on the boot but it wouldn't
close, so I took it off and stuck it around the boot opening on
the body.. now it closes fine, probably due to the internal hinges.
#1688 camp freddy
camp freddy
  • 3,696 posts
Posted 26 June 2009 - 09:08 PM
Jobs to do
washer bottle and pump * done
washer switch *done
wiper switch *
tacho pickup done
water temp pickup
strenghthen boot lock done
stamp chassis plate
jobs underlined now done :(
that's about it.
also finished wiring up the head lights, and got the headlight
flasher working properly...
apart from fitting the speedo pick up he's ready enough for the mot
Edited by camp freddy, 26 June 2009 - 09:08 PM.
#1689 camp freddy
camp freddy
  • 3,696 posts
Posted 26 June 2009 - 09:32 PM
just ordered some new switches for the switch plate
all with emblems
headlight switch
wiper switch
washer switch
and connector blocks for above
£33.94 incl p&p
#1690 1275 SPRITE
1275 SPRITE
  • 1,188 posts
Posted 26 June 2009 - 09:34 PM
quite alot done then tonight.
what about the wiper switch?
MOT tomorrow then?
EDIT: you posted when i was posting lol
Edited by 1275 SPRITE, 26 June 2009 - 09:38 PM.
#1691 camp freddy
camp freddy
  • 3,696 posts
Posted 26 June 2009 - 09:47 PM
MOT tomorrow then?
the wipers are still on the old wiper stalk until I get
the new switches, can still MOT it like it is..
Just want to get the speedo drive sorted if poss but
don't think it will matter if it isn't actually working as
long as it has got one, suppose I could butcher the
old one just so it's working.. :(
#1692 1275 SPRITE
1275 SPRITE
  • 1,188 posts
Posted 26 June 2009 - 09:49 PM
the speedo isn't part of the MOT anyway, but it would be nice to have it working :(
#1693 camp freddy
camp freddy
  • 3,696 posts
Posted 26 June 2009 - 09:53 PM
I could always use my road angel which shows gps speed !
I have also got to change over my insurance before I MOT
It will be a pain if Ratty fails ....
Also need to stamp the new vin plate..
Edited by camp freddy, 26 June 2009 - 09:54 PM.
#1694 1275 SPRITE
1275 SPRITE
  • 1,188 posts
Posted 26 June 2009 - 10:01 PM
yeah it would be a pain, but I cant see it failing because all the rot has been cut out and replaced, and all the ball joints are new etc, and if everything works, like washers, wipers, horn, lights, hazards etc, then there is no reason why it should fail lol...
#1695 mighty mini jack
mighty mini jack
    Mighty Before a Pint
  • 5,095 posts
Posted 26 June 2009 - 10:02 PM
Pricey switches!
Dont suppose they're the 'savage' ones are they?
Think they're brushed stainless or something
Maybe not though :(
