The Rat
#1621
Posted 18 June 2009 - 10:35 PM
#1622
Posted 18 June 2009 - 10:41 PM
should look nice with the speedo... might need to paint the
bezels though..
#1623
Posted 18 June 2009 - 10:43 PM
Actually I keep trying to get there before they shut, but they are always closed when I finish work, because there is a set of 6x12 wheels on a rusty white mini that I quite fancy to refurb and fit on mine.
he lives there, you could always pop round or phone
#1624
Posted 18 June 2009 - 10:45 PM
The gauges look good! Are those the ones you went for, oil pressure and water temp?
#1625
Posted 18 June 2009 - 10:50 PM
going bed now , see you later, you know where i am if your around..
Edited by camp freddy, 18 June 2009 - 10:52 PM.
#1626
Posted 19 June 2009 - 09:49 PM
put a fuse in the pump feed and connected it up, found that the
inlet manifold wouldn't allow the bottom of the carb (hif44) to clear
the bulkhead ,so it was holding off on the head
another more compact one , so I swopped them over
spark , but couldn't get the bloody thing to fire up... tried for most of
the evening , but decided to leave it and try with a fresh head tomorrow!!
Lets hope it's something simple
#1627
Posted 20 June 2009 - 09:25 AM
#1628
Posted 20 June 2009 - 12:36 PM
#1629
Posted 20 June 2009 - 06:15 PM
Quick question, is there enough room for your bootlid with the filler cap there? Thanks
boot shuts nice, fitted it this afto
#1630
Posted 20 June 2009 - 06:35 PM
#1631
Posted 20 June 2009 - 06:45 PM
Did you get the engine going?
Ditto
#1632
Posted 20 June 2009 - 07:14 PM
found a few probs while trying to start the motor !
found that the dizzi drive had previously been fitted
180 degrees out !! and I had some how set the rockers
with a .80mm gap
After a bit of messing finally got Ratty running !!!!! Yipee!!!
Think he sounds quite good !!!
Well here you are...
http://s192.photobuc...newyear0002.flv
http://s192.photobuc...newyear0004.flv
Mmmmmm nice!!!
better sound that vtec TRUE MINI !!!!!!
Edited by camp freddy, 20 June 2009 - 09:44 PM.
#1633
Posted 20 June 2009 - 07:22 PM
Sounds a little lumpy on idle too, so that cam in there should give it some grunt
I love that exhaust
#1634
Posted 20 June 2009 - 07:54 PM
well been uploading the vids to photobucket...
with a .80mm gapDoh!!!!!
The he sounds quite good !!!
Mmmmmm nice!!!
That sounds awsome, What exaust was it that you modified?
Mine ran for the first time in 6 months today
#1635
Posted 20 June 2009 - 08:50 PM
