What Do People Use To Stop There Windscreen From Fogging Up ?
Posted 04 January 2012 - 09:53 AM
also what do people use to clean the inside glass , there seems to be a residue on one of my windows and ive used glass cleaner but no joy
Posted 04 January 2012 - 10:48 AM
Posted 04 January 2012 - 10:54 AM
I use Auto-Glym fast glass to clean my windows, although sometimes they have some really caked on muck so I clay them first.
Edit: Might be worth working out what's up with the heater if it's not doing its job. It should be somewhat efficient, even on the screen setting.
Edited by bcjames, 04 January 2012 - 10:55 AM.
Posted 04 January 2012 - 11:29 AM
Posted 04 January 2012 - 11:35 AM
Heater on. Driver's window open. Job's a good un.
This
Posted 04 January 2012 - 11:43 AM
Posted 04 January 2012 - 12:07 PM
Edited by dow62, 04 January 2012 - 12:09 PM.
Posted 04 January 2012 - 12:08 PM
+1Heater on. Driver's window open. Job's a good un.
or you could try not breathing when your driving your car
Posted 04 January 2012 - 12:31 PM
The second common one on a Mini is where people ditch the big pipe between the heater and the inner wing and block the hole off in the inner wing. That big pipe is where the heater gets fresh air - without it and if the hole in the inner wing is blocked then the heater is only ever going to circulate the already damp air inside the car. There should be a plenum chamber under the wing and that should have a pipe going under the wing to emerge at the front of the engine bay to draw air from behind the radiator grille (early cars have an ever so slightly different setup but the concept is the same). Usually that pipe has a foam liner - if it's soaked then you are forever going to be drawing damp air into the car. Make sure all these pipes are intact and connected and the heater will stand half a chance.
After that it's making sure that the heater is working -
does the matrix get warm? or is it blocked/disconnected?
does the fan give a decent draught over the screen when the selector is in the screen position? If not why not? are the pipes to the screen vents connected at both ends? Is the flap inside the heater moving and sealing to force the air up to the screen? Is the fan actually generating some air movement?
Iain
Posted 04 January 2012 - 12:33 PM
a towel ;)
THIS AND THIS :thumbsups: works well for me
Posted 04 January 2012 - 12:39 PM
Posted 04 January 2012 - 12:46 PM
Posted 04 January 2012 - 12:54 PM
Edited by mab01uk, 04 January 2012 - 12:55 PM.
