Ignition Timing Runs Better With +12 Deg.
Posted 02 January 2012 - 07:49 PM
is it normal for my ignition timing to be so far advanced.
car runs much smoother with the timing, this far advanced.
i do have eletronic ignition.
and a piper 270 camshaft.
its it a fueling issue why it needs to be so advanged, or due to the changed parts.
any info would be great.
thank steve
Posted 02 January 2012 - 07:54 PM
If the advance is not sticking and there is no hint of pinking then I would leave it where it is.
Posted 02 January 2012 - 08:14 PM
Posted 02 January 2012 - 08:20 PM
Posted 02 January 2012 - 08:30 PM
the dizzy does advance when rev are increased so the advance still works.
I would say that the advance curve built into the distributor is no longer suitable for the engine mods you have carried out or the centrifugal advance mechanism is sticking.
if this is the case what do i need to correct it.
Posted 02 January 2012 - 08:43 PM
The general overall impression I get from the replies is that 12 deg is not really excessive, and if the car is running well at that,then leave it as it is.umm so mixed view.
I think the Aldon distributors have a advance curve more suited to cars with tuned engines, and perhaps someone with more experience than me can advise you on this.
The all singing and dancing cure is fully mappable electronic ignition eg Megajolt, which is labour intensive and expensive.
Posted 02 January 2012 - 08:44 PM
Posted 02 January 2012 - 09:32 PM
that why i used 12deg as it closer to 0deg.
unsure of compression ratio soz. do to having a pocketed block.
i will use more if you have had better results. what dizzy are you using
Posted 02 January 2012 - 09:38 PM
i have a choice of three. unsure which to go for really. SU2 on/ Hiff 38 On mini sport manifold or weber dhoc on my custom built manifold.
i have the SU2 on atm as i know the set up works.
Posted 02 January 2012 - 10:02 PM
I never set my advance at idle. I warm the engine after adjusting the valves, then bring the RPM up to about 4000 using the idle adjustment screw. With an advance type timing light I set the timing to about 32 BTDC and tighten the distributor clamp. Then the idle speed is reduced to the desired value and the car is test driven. Place the car under load in too-high a gear (like accelerating uphill in 4th gear starting from a very low road speed). If you hear pinging or knocking, stop and retard the timing a couple of degrees then repeat your road test.
Timing with the max advance and load testing will give you the maximum advance your engine can handle for its general condition and the fuel you are using. If you go back and check your idle advance after setting the timing this way I can almost guarantee that you will have more than 10-12 degrees.
Posted 02 January 2012 - 10:19 PM
but i will try advancing the timing more.
thought i might do some damage. so i kept trying to retart it. never mind live and learn
Posted 02 January 2012 - 11:23 PM
Edited by bmcecosse, 02 January 2012 - 11:24 PM.
Posted 03 January 2012 - 08:33 AM
Hello again. No,gave up on dizzys a while ago. When I gave up with the dizzy I had the mechanism all locked off and just set timing as much as possible without pinking. Megajolt all the way.It doesnt pink now!! So nice to be able to pull over when driving,tinker with the advance and drive off again.The beauty being that you can use massive idle advance but set a nice low cranking advance.Spec is in my profile but I have twin hif 38s.That hasnt made the slightest difference,the idle advance was the same with a single 38 and 44. Bythe way,get a chair. My idle advance is 33deg as it is throughout mostly--well it goes to 36 at very high revs.But drops to as low as 15 under hard acceleration. Sorry to totally kerfuffle you with these figures,they are accurate being megajolt,but thats just telling it like it is. You can probably ignore most of it whilst retaining a dizzy.also wonder pigeonto, what carb are you using.
Posted 03 January 2012 - 05:35 PM
it revs up and idles nice.
its just flat when i go to drive it. as i live on a very steep hill, it will not go up.
any tips.
i did advance the timing but wasn;t making much difference, untill i got to a point when it was to far advanced as it was stoping it self from turning over.
Posted 03 January 2012 - 06:03 PM
i hate carbs and dizzys
i had a look at the megajolt kit, i intrested in one but not got a spare 400 quid atm.
