Having some electrical problems with my Thirty... My rear lights, instrument lights, radio, mood lighting (not standard obviously
So in an attempt to fix these problems I replaced every spade connector that connects to the fuse box, and I also cleaned the fuse box up with electrical contact cleaner... I replaced everything in the exact same way and for a while everything was perfect, but recently things have been playing up again.
I have an idea that its actually the fuse box itself so I am looking to replace it. To save myself from spending £10-15 on a mini 4 way fuse box, I would like to modernise it and buy a cheapy 8 way Blade Fuse box (£3-ish).
I'm trying to figure out how the fuse box in my mini works, because I have 2 spades on one side and one coming off the other in some cases, but there is no pattern and the haynes isnt helping. My idea is as long as everything is still connected to everything that it originally was, things should still work?
What are your thoughts on this
Cheers,
Dom
