Wahoo, some progress in the right direction!
First of all, new tyres!
I've spent so much money on engine parts, tyres, a new engine (not fitted yet) and other bits, when you sit in the car it still looks like a wreck! Well thankfully that's changed as I finally got round to fitting my doorcards and alloy handle set. Took a bit of fettling to get the lock surround on as there was nothing to screw in to, managed to get it sorted in the end though and they look 10x better.
Before
After
They were a bit of a swine to fit, had to drill out the holes in the door as they were full of weld and filler for some reason. Some of the holes were too large too, on the drivers side door, the clip nearest the lock, the hole is huge so I'll have to whack some silicon behind it tomorrow to make it stop popping out. I also waterproofed the back with a simple piece of plastic from the workshop:
I glued the leatherette cover I bought, on to the padded lower dash rail. I'm having a bit of a nightmare getting it all to fit properly though. I've bought a new switch panel, new choke and new heater cable too.
My problem is that I can't get the switch panel to have the bolts through the holes and not look crap. If the switch panel bolts go through the holes, then the panel itself is 1cm in at the bottom of the padded dash rail but sticks out the top. Doesn't help that the switch panel got a bit bent during fitting (it's one of those chrome ones). Spent about an hour fettling with it but still couldn't get it right then ran out of daylight. To anger me even more, I've lost one of the bolts from the switch panel brackets too and I'm buggered if I can find another that fits - does anyone know the size of the bolt of the top of their head?
Left it like this for today:
I'm planning on waking up early and having a bash before work but I need to find another bolt that will fit before I crack on, had a long day at work though so was too tired to search the garage for the elusive bolt. I must start taking care of the bits I take off.
Next step: fit lower padded dash rail and switch panel, connect up choke and heater - no more using my right foot as the choke!
Next job: When new rear arch covers arrive, fit them and then fit new rear cards.
