The Start Of My Vtec Mini
#211
Posted 17 December 2012 - 10:32 PM
#212
Posted 17 December 2012 - 11:36 PM
#213
Posted 18 December 2012 - 04:21 PM
Also I has a quick test drive what a machine It realy did not hit me how much power this thing has and I still have not go. Over 4000 rpm lmao
#214
Posted 18 December 2012 - 05:56 PM
#215
Posted 18 December 2012 - 10:29 PM
A few of my neighbors where asking where is world war 3 going on and some of them said where are the kids with the bangers lmao
any way it came to saturated morning ant i was thinking hard about why it was doing this mabie lack of fuel so i put another £15 in the tank just so i now its getting a good supply terns out it wont go at all i checked every thing timing got a new set of plugs map sensor reading did every test i could on the ecu side of things still nothing then Dave told me about the cps sensor witch is inside the dizzy i took the dizzy apart to find it was wet inside rusty and it looked abit like scrap i used easy start to clean it out then i sanded all the connections sown to clean metal i put it all together and she started first time and ran beautiful
Inside the dizzy this pick don't relay do it justis
Then another video this time it was running lovely this is not me driving
Edited by johny:), 18 December 2012 - 10:49 PM.
#216
Posted 21 December 2012 - 10:17 PM
i had a horrible engine knocking noise coming from mine, it was getting worse and worse.
it turned out to be a very loose spark plug. problem solved!
#217
Posted 22 December 2012 - 09:43 AM
I have now wired up a mini loom so hole cars electrics now work :) well I still have a tail loom to make also I'm ditching the obp box and makeing a mini one work that obp box is just crap and is flexing way to bad
#218
Posted 23 December 2012 - 08:33 PM
#219
Posted 02 January 2013 - 10:00 PM
Any way my New Years resolution is to have my mini ready for the road to do a few shows in the summer I have done allot of work other Christmas so I have a big update to do
#220
Posted 18 January 2013 - 08:01 PM
any way to start of i wanted to sort my pedal box out as the obp box was flexing under load i had enough of it and its problems so i pulled the hole lot out and tried to refit a mini pedal box that was a fail as the mini tec right hand drive kit was in the way but i had gon to far to turn back so i started off with my good friend mr angle grinder and cut a square out well its not very square in this pick
So i had a second attempt to fit the pedal box my idea was to lower the floor around the steering rack so that the pedals go into the floor
attempt number to and we have lift off it fits
i welded the pieced that i made into the floor i dont have a pick of it finished sorry as my hands are always dirty and a white phone dont mix lmao
i tried fitting the obp master cylinder and punny enough it just droped in over the original bolts
i got it all plumed in and it works the pedal is a bit height so i am going to adjust the length of the rod some time to lower the pedal i have tried to fit a break master cylinder and i just need to plum the cluch feed in different o itt misses the break master cylinder i need to order a new one so i will update on that later on
I then decided to start in the wiring i opened a mini loom up and took what was not needed out for example oil preshure, altinator, temp,clocks,
I tested it all on the floor then fitted it all to the car what a night mare but i did get it all working then then lights ect are all back in i will do a video of it all working i wired it all into the honda clocks and i evan have stuff like a boot or door open light and a hand break light what a posh mini
I also got these there nice and loud so people will hear me from a mile away
As the weather was starting to warm up abit i then set about finishing the body work i had brand new a panels sitting in the corner for months just never got around to fitting them so i choped the old ones off to find the pasinger one full of filler any way
For a change the A panel fitted quite nice and it was a nice job to do so i was happy with that
finished product
I alsp bonded a plate onto it to hold the wing on i used tigar seal but it was an epic fail and fell off at the first sight of stress so i ended up welding them on i will get some picks up on my next post this was it bonded on any way
So then it was the big job of sanding the rest of the paint oh what fun it took me and a few mates a full week of sanding evan with the sander
but it was a good job done
boot is not quite finished there
the roof took ages and ages what a job
There where a few dents in it i tried my best to fill them out but they will proberly still be visible but at the end of the day im no body shop man and this car has had a hard life as long as it looks of i will be happy as its only a toy not a show car
I also bort a honda in the new year for scrap with a b16a2 engine a made a nice profit on it so that boosed up some money to spend on the mini any way i stole this off it and it fitted in the holes that where in the bonnet for the mini badge
I got some etch primer in ready to give it a first lick of paint it was quite cheap as well
all back to the bare bones she was ready for some paint
all masked up
and from behind looking good now
I did all the priming and body prep and my dad is going to do the top coat as he is a much better painter than me
Then a few coats of primer later and its all one colour again
no more body picks for now as we are nee deep in snow and its gon far to cold to put any more paint on but i have fitted the boot back on filled a few more little dents and flatted it ready for gray primer then i can paint the roof and then finely the car hopefully the snow will be gone soon and it will warm up abit but i have came to a stand still now
i got this for a barging of £50 delivered im not going to fit it untill the car is on the road as i wont to now the engine runs fine first
hope fully have a new update soon and with any luck it will have paint 10 points to any one who can ges the coloure lmao
#221
Posted 18 January 2013 - 08:22 PM
PINK! PINK! PINK! PINK! PINK! PINK! PINK! PINK! PINK! PINK! PINK!
#222
Posted 18 January 2013 - 11:25 PM
#223
Posted 18 January 2013 - 11:40 PM
I don't want to ruin the surprise, i shall wait and see
Kieran
#224
Posted 19 January 2013 - 12:37 PM
#225
Posted 19 January 2013 - 05:11 PM
Thanks Paul that is a good question I don't now realy as I have no carpet but I do now that when the cluch pedal is down at its furthest point it does not touch the floor and I also stil have cluch over throw so I think it should be ok
The worst case is that I may have to cut a square out of the carpet
