The Rebuild - Track Orientated This Time.
#46
Posted 10 November 2012 - 07:57 PM
#47
Posted 10 November 2012 - 08:52 PM
Edit: found it.... http://www.statuserr...on-thrll-http-t
Edited by jonny f, 10 November 2012 - 08:54 PM.
#48
Posted 11 November 2012 - 12:37 PM
#49
Posted 11 November 2012 - 08:05 PM
#50
Posted 16 November 2012 - 06:56 PM
No pics either as they're just plastic windows
If any of you guys want Polycarb windows; these are the people to go to:
http://www.acwmotorsportplastics.co.uk (A new site is due to be released in the next few weeks.)
Plus TMF'ers get 10% off!
#51
Posted 16 November 2012 - 08:33 PM
#52
Posted 24 November 2012 - 06:25 PM
Update:
The inlet runners had O ring grooves in them which created a void when I ported them to match the inlet manifold ports. So some chemical metal and a bit more grinding later and we have:
I also got a guy at work to drill blind holes and tap them for me leaving the head side of the flange untouched. Runners bolted on:
I did also buy some silicone to create a tight seal but the instructions said specifically not to use with fuel so I'll find another sealant to finally bolt the runners on.
Bought an accelerator pedal too but it seems awfully big to me? It may be a different story when I can actually offer it up to the body but its almost twice as heavy as the original mini one. I'll just have to lose the weight somewhere else ;)
It's a lot beefier so should withstand some heavy right footed action. I might trim it down, depending on what the ratios are like with the ITB's.
Got some stainless top arm plates and some more 12pt bolts to go with them. The plates are pretty heavy as well but they were cheaper than their steel equivalents. I bought them to get dimensions from because I'm looking at getting a batch of Ti bits cut but I have no idea what that'll cost so I might end up using them anyway.
I also managed to score a lightened flywheel from ebay but that hasn't arrived yet.
Edited by kcchan, 24 November 2012 - 06:26 PM.
#53
Posted 24 November 2012 - 08:11 PM
That pedal looks crazy!
#54
Posted 02 January 2013 - 09:31 PM
So I dug the doors out and did some lightening. The small holes were to separate the lower half of the window channel from the frame as it was removed to reduce weight further. They were welded up and a new hole was drilled in the right place and swaged to suit.
The bottom on the drivers side need a little repair, then they'll be ready for some alloy skins. The edges of the inner frame will be neatened up, then either have some trim added to it, or will have alloy/carbon "cards" if they feel a little flimsy.
That's it unfortunately. Currently rebuilding the "rebuilt" radius arms I bought as I'm not happy with them.
#55
Posted 02 January 2013 - 09:47 PM
#56
Posted 03 January 2013 - 01:27 PM
Al
#57
Posted 19 January 2013 - 07:20 PM
i've got titanium top arm plates for mine, got them cut at work. they weigh almost nothing!
#58
Posted 19 January 2013 - 09:53 PM
I had a quote for the plates but it was too much. I also got a quote for a larger batch but no one else seemed interested in them so I didn't bother. I'm waiting for a few ali bits that I've had cut to arrive though.
Don't suppose you could get me some Ti bits cut as well as the turn buckles? The only other thing I wanted in Ti was rear drum hand brake arms. Have you thought about those at all?
#59
Posted 19 January 2013 - 10:06 PM
http://www.titanclassics.com/
might not though looking at the site.
#60
Posted 19 January 2013 - 10:16 PM
i hadn't thought about those until you mentioned them! are the original riveted together? you thinking of just bolting with a nylon washer inbetween or something? i'll have a rumage in the scrap bin to see what thickness material is available then i'll have word with the laser man to see how nice he's feeling haha
when do you need the turn buckles for? won't know how much material i have left until i've finished off my kit. you using standard steering arms? just so i know for the turnbuckle length
